Nodes not deleting
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Sorry, I think that there is a misunderstanding... you cannot use the Delete key to delete nodes in the Node Editor, you need to right-click on the node and chose Edit/Delete:
ciao Beppe
bepeg4d wrote:Sorry, I think that there is a misunderstanding... you cannot use the Delete key to delete nodes in the Node Editor, you need to right-click on the node and chose Edit/Delete:
ciao Beppe
Because of lack a DEL key it's not working. I've added a support for BACKSPACE key. Will be available with the next builds.
Return to “Bug Reports”
