Cinema4D version 2020.2.1-R3 (Obsolete stable) 23.03.2021
about Mac CUDA version, there is an issue with 2020.2.1 SDK, AI Denoiser, and 4x4 AI Upsampling:
The core devs are investigating the issue, I’ll keep you posted.
ciao Beppe
Kalua
Hello, Aoktar
I got this error after plugin C4D OCtane gradient into a opacity channel.
I attach screenshot and bug report.
EDIT: other nodes have also caused problems with opacity.
Regards,
octane 2020.2.1 210311 194653.log
(6.87 KiB) Downloaded 211 times
C4D 2025.1.1 Octane v1.9 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
bepeg4d wrote:Hi Greggers,
yes confirmed, Toon material is giving CUDA error 719 in 2020.2.1.
We are investigating the issue, in the merantime, please go back to 2020.2-RC6 for scenes with Toon material:
viewtopic.php?f=85&t=76633
ciao Beppe
The core devs have found the issue and will be fixed for the next SDK update.
ciao Beppe
ralf_breninek
THANKS AOKTAR for patching back in the "use denoised beauty pass" :D
I just recently installed the 2020.2.R3 like 3-4 days ago and yesterday wondered where this function has gone to but also saw the 2020.2.1 was released in the meantime. You people are faster than I do update my software, thank you and your team.
C4D R21.207 / Octane for C4D 2020.2.4 / Watercooled 4 x EVGA Geforce RTX 2080 ti
http://www.pixelasm.com
Interface and motion graphics design for interactive interfaces and animations on TV, web, mobile and automotive from Köln / Cologne Germany
ralf_breninek wrote:THANKS AOKTAR for patching back in the "use denoised beauty pass" :D
Decided to bring back it! It was here but hidden for sRGB colorspace, shown it again.
blackcat321
I have a problem. If I turn on viewport rendering, I can't record keyframes
zoppo
2020.2.1 - you fixed the store render buffer problem :)
Two problems though:
1)
When using the live viewer and render region the rendering just stops after 60 samples.
Without render region it works fine. Film region works fine, too.
2)
Composite material has no tab where I can see, what objects it is applied to.
C4D 2025 | Win10
blackcat321 wrote:I have a problem. If I turn on viewport rendering, I can't record keyframesImage
I can do, please give detailed info! What's OS/C4D versions? And what kind of scene?
zoppo wrote:2020.2.1 - you fixed the store render buffer problem :)
1)
2)
1) Crypto passes cause this, not plugin issue.
2) I know but no way to do until now
Again that's interesting nobody gives feedback for performance/stability improvements, just problems. Ok, we assume this is a really good performer. Thanks!
Return to “Releases”
