Parallax mapping OSL shader
jobigoud
Here is an OSL projection shader that implements Parallax Occlusion Mapping. This is a way to simulate displacement without actually adding new geometry.
Compatibility: Octane 2020.2 or higher.
parallaxMapping.osl
(5.23 KiB) Downloaded 244 times
Very basic test scene, experiment with your own materials and textures.
parallaxmapping.orbx
(273.93 KiB) Downloaded 247 times
Manual setup:
1. Add a Projection node of type OSL projection and point it to the OSL file.
2. Plug the displacement texture into this node.
3. Set the projection on the displacement texture node to "OSL delayed UV".
4. Use the parallax mapping projection as the projection for any texture used on the material.
5. Play with the Depth scale value to tweak the effect.
A similar shader was also published a while ago in this thread: viewtopic.php?f=33&t=71968&p=364916
One of the differences is that the one here uses a texture node as input instead of a file name.
Don't hesitate to send remarks, usability suggestions, bugs, advantages/drawbacks compared to Texture or Vertex displacement, etc.
linograndiotoy
Very cool!
I imagine shadows can be a problem, right?
jobigoud
Yes, unlike actual displacement this does not support cast shadows.
Jolbertoquini
Thanks for the update, the one I post here on the group the depth was annoying embed on the script this is better Thanks for the help! I hope we will have something on the future to help with the shadows but with a strong normal map kind fake a bit is some cases can be awesome for background stuff.
Best,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Tugpsx
This is cool thanks for the update.
whersmy
Interesting. As I`m typing this I`m adding a carpet with osl-baked displacement onto a displaced wood floor.
Maybe it could be interesting to see the difference vs renderspeed/stability :?:
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
