Problem with saving images ( urgent )
justix
After a long while I'm back do some work with the latest 4.05 - 6.34 BUT the saved image is not what I see on the screen, is like the color palette gets wrong on saving the render, is there somewhere I should look to fix this? attached some examples
What I got on the screen:
And these are the saved images, notice the Color gets smear and it is stronger in the denoised saved image, the JPG option is just the same
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
paride4331
Hi justix,
Octane plugin version?
samsue
I find it interesting to see how many posts on the forum are related to how to save the render.
justix
paride4331 wrote:Hi justix,
Is mentioned in the post 4.05 - 6.34
justix
samsue wrote:Paride
Never had this issues before with saving a render with OCtane as I remember, what I see on the screen should be what I get on a file
paride4331
Hi justix,
just to clarify, are you using Octane v2020 opening a v4 scene or are you using Octane v4 opening a v4 scene?
justix
Using V4 with a V4 scene
paride4331
Hello,
did you repoduce this test using SA encountering the same issue?
Return to “Autodesk 3Ds Max”
