OctaneRender® for 3ds max® v2020.1.5 - 10.20
mbetke
Can't connect node 'oDiff_07 - Default' (NT_MAT_DIFFUSE, 0000015520391680) to static pin 'layer' (P_LAYER, type PT_MATERIAL_LAYER) of node 'Universal material' (NT_MAT_UNIVERSAL, 000001552038CD60)
Getting render errors while in mid of rendering when I change response to other LUT. It's a common error. No Vram problems with the scene. Need to close the viewport and re-open it again. So a annoying bug.
I also still got the strange image transparency on some renders in combination with denoiser and .png saved files. I reported it some time ago.
PURE3D Visualisierungen
paride4331
samsue wrote:https://1drv.ms/u/s!AmKlVgIcgYzFgfFLdAUegwNW1lOh2Q?e=zaPYhl
Hi samsue,
I did more test; I found the issue but I can't replicate it every time.
I sent my scene test to the developers.
paride4331
mbetke wrote:
Hi mbetke,
There must be other elements involved causing this issue, I can't replicate it, also testing massive scene.
removing the scene and leaving just the camera, any crashes?
mbetke
Hi mbetke,
How can I find out which material is it? And why does it sometimes work in the same render session but suddenly I get this error?
mbetke
The imager image and also the saved image does look different from the interactive viewport output. You can see the black areas on the tree. In viewport all is okay.
paride4331
mbetke wrote:The imager image and also the saved image does look different from the interactive viewport output. You can see the black areas on the tree. In viewport all is okay.
Hi mbetke,
viewtopic.php?f=27&t=76257#p392467
mbetke
Strange because I use the same tonemapping workflow for years and it appeared now and only with some scenes.
p3taotoy
Tooootallly NOOOB question here...
Where is teh menu to export to ORBX.
I got what I see in the viewport... now I need to get that to the standalone for other reasons
Its not under file export... unless I need to turn something else on??
Peter
p3taotoy
Found it...
No need to reply
Peter
Templas
I have a question why the ZDepth channel looks good when rendered, but when saved, it becomes striped
Return to “Releases”
