Issues when trying to render a scene...
Tigersan
Issue when trying to render... This is what shows up...
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser 11\Runtime\Python\addons\OctaneRender for Poser\__init__.py", line 87, in Render
File "C:\Program Files\Smith Micro\Poser 11\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 5395, in ShowSetupForm
File "C:\Program Files\Smith Micro\Poser 11\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 192, in CreateNodesFromPoserScene
File "C:\Program Files\Smith Micro\Poser 11\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 945, in ConvertMaterial
KeyError: 'bumpmap_uTranslate'
What could be the issue here?
When that happens Octane gets stuck in the initial loading of the objects and meterials, so i dont even have materials loaded, it freezes in this state,
and i left it there for over 30 minutes and noting happens... :(
Octane Render for Poser ver. 2020.1.5.104 Studio
Poser 11 build 11.3.818
Windows 10
128GB RAM
2x Nvidia 3090
Nvidia driver 461.09
The Octane plugin stops working as it was giving up, poser isn't locked as it usually is when Octane is loading. The logs dont show anything, as if the
situation never happened, the timecode when it happened is not present... When I open materials tab its completely empty... I dont know whats up...
My Artstation profile: https://www.artstation.com/tigersan
Software: Poser 11 Pro, Octane Studio 2020.1.5.104, Adobe Suite
My RIG:
Operating system: Windows 10 Pro 64
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
HDD: 2x WD Gold 7.68TB U2 NVME
Tigersan
Where am I supposed to get those files??? In a different folder there are pyc files, i tried just changing their extensions to *.py but they dont work that way...
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
Erick
I'm sorry, I'm not being a real help here, but just want to remember, that Paul left a few notes (also in red) in the very 1st post, of the topic "OctaneRender 2020 for Poser [TEST and STABLE]".
viewtopic.php?f=45&t=73536
Maybe they can be of help somehow.
Tigersan
Erick wrote:I'm sorry, I'm not being a real help here, but just want to remember, that Paul left a few notes (also in red) in the very 1st post, of the topic "OctaneRender 2020 for Poser [TEST and STABLE]".
Thank you... The problem is it gets stuck before loading any materials, so my materials window is empty... the most of the points in that post
don't apply to my situation though... Thanks for trying to help :)
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
wimvdb
The problem is caused by having a bump map connected to the Gradient bump in Poser surface. If you connect it to the bump channel the problem goes away. If this is the case, check all materials for the same problem, usually the creator of those mat files uses this method in all materials.
The gradient Bump node needs either a specially formatted BMP file (Gradient Bump mode) or and NORMAL map (tangent or Object mode).
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
Tigersan
wimvdb wrote:The problem is caused by having a bump map connected to the Gradient bump in Poser surface. If you connect it to the bump channel the problem goes away. If this is the case, check all materials for the same problem, usually the creator of those mat files uses this method in all materials.
In the scenes where that happens im not using any gradient bumps...
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
wimvdb
I have that problem regularly when I use "old" props.
It used to be no problem, but in one of the latest versions of the octane plugin it became an issue and caused this problem.
If you use any 3rd party props, check if anything is connected to the gradient bump.
Tigersan
You were right! The problem was with the poser nodes, i removed blindly some of them that were not recognized by Octane and it started working thanks for giving me a clue! :)
My RIG:
CPU: Ryzen 5900x
RAM:128GB RAM
GPU: 2x Nvidia 3090
Return to “Poser”
