new render, old problem
nico_cad
sorry i've a problem.
render with alpha channel and see all black currectly but the glass isn't with alpha.
why!!!??? :oops:
juanjgon
Are you using the specular material? In this case, I think that you need to enable the affect alpha option.
nico_cad
thnaks for answer.
i've enable affect alpha option on specular shader but there is white part.
juanjgon
How about the other options "fake shadows" and "thin wall"? The problem could also be related to the specular or glossy depths in the kernel node.
nico_cad
fake shadows - if active or disactive not change :geek: .
post kernel and glass surface.
juanjgon
Hmm, I'm not sure why your object has this behavior. Perhaps it is the expected alpha rendering due to the refraction light being. Have you tried to set the refraction to 1.0 to check what happens?
nico_cad
nothing...with refraction to 1.0 not change. :cry:
change it in post.
:evil:
Return to “Lightwave 3D”
