Hey,
Another 'bored in the hotel, buy and octane up a model' job.
The model came with a plain yellow body, so i decided to add a map to it with the classic racing green/yellow stripe colours.
About 2 hours of work in blender to import the max model, clean it up and approx 20 minutes to materialize/light/tonemap it in octane.
Rendertimes were approx 10 minutes per image on 2x GTX460, with default pathtracing settings, rendered at 2x res and downscaled with a sharpening filter in pshop,
The model has about 1 million triangles.
Tonemapper uses a Kodachrome 200CD response curve with slightly more gamma to reduce it's contrast a little bit. (1.16)
There's also a 0.6nm thinfilm on all the glass, it's quite visible on the headlights.
Radiance
Lotus Elise Type 25 Racing Green
wow! another cool one how did you achieve the glistering particles effect in your metallic car paint? was it procedural or texture?
then the first image cld use some background.
but thats just secondary anyway
gigabyte mobo, core2quad, 8gb ram, x2 pny gtx 580,
hp pavilion hdx series(desktop replacement) 4gb ram, gt 8800
win7 x64bit, octane 2.3 v5
Metallic is simple, use a mixed material with two glossy inputs.anomi wrote:wow! another cool one how did you achieve the glistering particles effect in your metallic car paint? was it procedural or texture?
then the first image cld use some background.but thats just secondary anyway
The first glossy should like a mirror and the second a little bit more glossy like a simple diffuse.
Mix they together and you get a metallic look.
You can add a little fractal bump an the second one to create more glitches...
Or you can play with the filmsettings to create wired stuff
face
PS:
It would be nice to have some mixing modes like Photoshop...
http://vimeo.com/user2509578
wow thanks FACE, that simple? and that cld take a lot of time to get, even maya's preset car paint shader to look excactly how u want it, let alone building urs from scratch
i highly support that photoshop style blending modes and a layer node for octane, that wld be awsome.
- teecee2107
Thanks a lot, Face ! This quick tut is just what I needed.
