Hello everyone,
I'm here since i have a big problem with c4d s22.123 and octane 2020.1.5. It happens almost everyday that cinema crash and when i'll try to restart the program it runs only as a process in the task manager, i'm forced so to restart all the pc so i can start again cinema. I've tried almost everything, from deleting some folders like pref,pyhton to fixing all the texture inside the materials but nothing as changed.
One last thing, most of my files cames from c4d R19.
I'm really lost about this problem so thanks in advice guys for any help
i'll leave some of the bug reports taken from the folder in the attachment
Here's my spec:
Proceessor: Intel(R) Core(TM) i9-9900K
MB: PRIME Z390-A
RAM: Corsair Venegeance 3200MHZ 64GB
GPU: RTX 3080(latest studio driver)
Cinema4d S22 runs only as a process in the task manager
- bugreport_20210119_143702.zip
- (1.41 KiB) Downloaded 165 times
- bugreport_20210119_141855.zip
- (1.35 KiB) Downloaded 164 times
- bugreport_20210119_141423.zip
- (1.38 KiB) Downloaded 162 times
- bugreport_20210119_141131.zip
- (1.35 KiB) Downloaded 178 times
Have you deleted other plugin dlls as readme says?
I'm trying right now since is super constantly(talking about crashes) and seems that when i try to open the rgb selector inside the node editor the window crash and so the program with the same result described in my first post.aoktar wrote:Have you deleted other plugin dlls as readme says?
I don't think S22 is a perfect version without any problems. I'd not advice to use it if you ask me
I'm trying also with c4d R21.207 seems more stable but the problem has appear also here, with a scene really really light, i'll attach the file i'm testing right now if can helps, looks like when i'm moving on the live viewer and trying to deform the alpha of a material starts to slow down and then crashes.aoktar wrote:I don't think S22 is a perfect version without any problems. I'd not advice to use it if you ask me
Thanks in advice anyway aoktar
- scene file.zip
- (218.86 KiB) Downloaded 174 times
First thing i've done so far, nope, that's not the solution unluckily, it appears again in the task manager but only there.mrom wrote:Just scroll down in the task manager to the Cinema 4D task and kill the task (right click or use the button in the bottom right corner). Then you can start C4D again without restarting the computer.
I don't think it's directly about us(Octane), If it happen while you open a window. Looks like an opengl and driver issue.
