How do I render a VDB sequence?
Forums: How do I render a VDB sequence?
Re: How do I render a VDB sequence?
Postby promity » Fri Jan 15, 2021 10:30 am
promity Fri Jan 15, 2021 10:30 am
Again I had to deal with VDB sequence and Octane and again problems.
I made a sequence in LP based on the demoscene for LP2019. I saved the sequence and created a new scene. Added a Null object and assigned the Octane volumetric modifier to it. Additionally, I assigned a volumetric LV to the same object for visualization in the projection window of VDB files.
As a result, if I use only one frame for rendering to Octane, it is displayed without problems. But as soon as I load the VDB sequence, there is no volumetric in the rendering window.
The screenshots show this. What am I doing wrong this time? )
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
promity
Postby juanjgon » Sat Jan 16, 2021 11:47 am
juanjgon Sat Jan 16, 2021 11:47 am
But do you have the right path for the file sequence? The path is not the same in the single frame screengrab. In the sequence, the filename is alone without any path.
juanjgon
Postby AndyM1969 » Sat Jan 16, 2021 5:30 pm
AndyM1969 Sat Jan 16, 2021 5:30 pm
I am getting a bit pissed off with my problem not being replied to, would appreciate you giving me a reply please before I need to take it the Otoy help and ultimately get my money back!
AndyM1969
Postby promity » Sun Jan 17, 2021 12:23 pm
promity Sun Jan 17, 2021 12:23 pm
juanjgon wrote:But do you have the right path for the file sequence? The path is not the same in the single frame screengrab. In the sequence, the filename is alone without any path.
Thaaaank youuuuu! ) Finally I got it! )
Lightwave 3d
promity
Postby juanjgon » Sun Jan 17, 2021 5:46 pm
juanjgon Sun Jan 17, 2021 5:46 pm
AndyM1969 wrote:I am getting a bit pissed off with my problem not being replied to, would appreciate you giving me a reply please before I need to take it the Otoy help and ultimately get my money back!
I wanted to ask the core devs if this is was the expected behavior, and we are in the middle of the weekend. In any case, I think that you have already got a reply.
juanjgon
Previous
Return to Lightwave 3D
Tue Jun 04, 2024 6:19 am [ UTC ]
