OctaneRender 2020 for Rhino (OBSOLETE)
Refracty
Hi Paul,
no problem, here you see that the texture placement is correct in the Rhino viewport but not in the Octane Render Viewport.
Hope that helps.
Best Regards
Nando
Desktop.zip
(213.18 KiB) Downloaded 635 times
Refracty wrote:Hi Paul,
Hope that helps.
Best Regards
Nando
Do you have a Rhino6 version of the 3dm file please?
Refracty
Yes, here we go
TestProblem_R6.zip
(203.1 KiB) Downloaded 647 times
Refracty wrote:Yes, here we go
Hi Nando - the Mix Material "Amount" pin needs the Projection set to "Mesh UV Projection" in order to use the mesh UV's.
Refracty
Hi Paul,
you are right, the projection hasn't been set to Mesh UVs.
I am very sure that I didn't change anything on that afer creation and thought it must be always default.
That is strange but it seems to work correctly.
Another little thing - The Material Preview is different from the Octane material even if it is rendered by Octane.
Is this something that can be fixed or do we need to set it somewhere?
Thank you
Nando
Hi Nando. The thumbnail looks OK on my system. Do you have the Rhino->Render->CurrentRenderer set to Octane?
Refracty
Yeah, the current renderer was set to Rhino.
OK, cool that helped.
Thank you Paul.
Have a great 2021 - You are the best
jihster
I'm having difficulty installing for Rhino 7 -- I receive the error "Error Starting Octane - Could not load OctaneWrapper.dll" but my graphics drivers are fully up to date.
My system specs below:
Windows 10
Intel Xeon E-2186M CUP @ 2.90Ghz
32GB ram
NVIDIA Quadro P4200 (driver date 2/27/2018, version 23.21.13.8908)
Is this a common issue?
jihster wrote:I'm having difficulty installing for Rhino 7 -- I receive the error "Error Starting Octane - Could not load OctaneWrapper.dll" but my graphics drivers are fully up to date.
Windows 10
32GB ram
Hi - I doubt drivers from 2/27/2018 are up to date. Does Octane Standalone run and start rendering on your system please?
jihster
Ahh thanks Paul, you're absolutely right. I had run the driver update and it had shown all drivers as updated from there, but I found a more up-to-date driver by going directly to NVIDIA. Sorry for the bother, and thanks for taking the time to respond!
Return to “Rhinoceros 3D”
