AdryanStrife
After trying different times with the "stable" version dowloaded from the official page, yesterday I found in the forum and installed the version viewtopic.php?f=24&t=76545 , and magically it started working, and which is best, it also started working the add-on of Blender. For the first time everything works, I can't explain why but it does.
luozhengan
Octane X Does support AMD Radeon PRO 580?
Jedi_blade
Weezer wrote:Well it’s the Christmas holidays and the middle of a pandemic, so I’m not expecting miracles at the moment. Give it time.
Oh I get it, but it says stable so I am confused if it is specifically and issue we are having or this is just part of this build.
Mac Pro (2019)
3.2 GHz 16-Core Intel Xeon W
96 GB 2933 MHz DDR4
Two AMD Radeon Pro Vega II 32 GB
After Burner
Jedi_blade
robbeedee wrote:
Pixege wrote:And I will ask again about these free licenses for those who bought a Mac in 2019 and 2020.
I am still holding back on buying an annual subscription because it was promised a year and a half ago.
Any dates known?
One year free trial of OctaneX. However, I cannot get it to work.
https://home.otoy.com/render/octane-render/demo/
I think that is the trial to Octane X. It was going to be a year of the commercial version. If it is the year sub for Mac owners it would defeat the purpose, one GPU would make owning a powerful Mac Pro Kinds of redundant.
Mac Pro (2019)
96 GB 2933 MHz DDR4
After Burner
Weezer
You could argue the plugin is stable – but there seems to be an issue with denoising in various builds. Fingers crossed it'll be sorted next week when we're all back to normal (or as normal as it gets these days).
CookItOff
I have a Studio license and I can't get the Octane Server with combined with the Octane Blender app to start/run on my M1 Mac Mini. The server will download and act like it installs but once I click on the server icon after moving it to the applications folder, nothing happens. The Octane Blender App instals and loads fine minus the server not connecting, obviously since the server app never starts.
I have checked the Activity Monitor and the Server App never shows up.
The Standalone version works fine.
Tim
wafflelad
I'm getting consistent crashes on my 2019 Macbook Pro with 5500M and Intel 630 when I have the Intel integrated GPU active. It happens on both C4D and Standalone. I don't need to use that GPU at all, but figured I should report the crashes. I've attached the Octane log file.
Joey
octane PR7 210103 113354.log
(4.59 KiB) Downloaded 434 times
joecurrie
Any update on when Octane X Prime will be released on Mac App Store? I see the plugins for Prime have been released on Otoy website. Is there a reason you can't release the standalone as well?
Edit - Octane X Prime PR7 seems to work fine in Cinema 4D without the prime standalone installed? Not fully tested but basic scenes seem to be running without problems, nice! (Mac OS 11.1, AMD RX 5700 XT)
Mac OS X 10.11.4 - Cinema 4D R17 | Geforce GTX980 + 980ti | 32GB
cgdoc
Joey
same here. The Intel integrated GPU should not be checked in the settings by default. It took me a while until I realized that this was causing crashes and a massive slow down of C4D.
Georg
Jedi_blade
Oh, I would not argue that I have a lot of random crashes that should not happen. Sometimes I will add a node and it will crash, and I will reload add the same node and it is fine. If that is normal then my view on stability is much different.
Mac Pro (2019)
96 GB 2933 MHz DDR4
After Burner
