Yes I can make more clever light-mixing preset(which can add passes for used light items) and more features to work faster/more efficiently: Copy/paste/duplicate/etc.. for AOV items, some revisions on render pass management also much more for AOV(when core brings).ndreimi wrote:I've been playing around with the AOV system with light mixing, and I just want to give a huge THANK YOU for this. I've envied Corona for light mixing for a long time now, especially when working with exteriors/interiors.
Aoktar, in the future, could there be anyway to automate the setting up of light mixing? Perhaps, a button that automatically gives all lights their own ID and automates the layering part of this process?
Cinema4D version 2020.2-RC5 (Release candicate) 23.12.2020
One question: shouldn't the Ray Switch node's textures actually connect to the main node?
C4D 2025.3.3 Octane v1.9.3 // Octane SA 2026.3, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
Hmm yes, apparently I missed pins.Kalua wrote:One question: shouldn't the Ray Switch node's textures actually connect to the main node?
- eyeonestudio
- Contact:
Thank You. RC5
Some Testing > Network Rendering is Working.(until now)
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
Hello Ahmet,
now that we have the AOV system, is there an option in the future of implementing per Light ID Post Processing such as Bloom and Glare, with different settings?
As an example, Light ID2 no Bloom/Glare, Light ID3 just Bloom (power1), Light ID4 Bloom (power50) and Glare.
Thank you!
Yassin
Thank you!
Yassin
+1y81r wrote:Hello Ahmet,
Thank you!
Yassin
And add more options to the Post tab,
like: Obstacle Image, Lens Dust, Lens Scratches,
like in V-Ray Next:
https://docs.chaosgroup.com/display/VMAX/Lens+Effects
Click +1 here if anyone needs this feature too:
https://render.otoy.com/requests/?qa=60 ... -scratches
System:
i7 8700K / RTX 2020 / 16GB RAM
@aoktar, is it possible to add a LUT or use a camera response with OCIO enabled?
I know we now have to enable "forced tone mapping" for it to work, but it smooths out all the highlights and looks very strange:
OCIO sRGB
OCIO sRGB + force tone mapping
BTW, could you add the ability to import LUTs as a node in the AOV Node Editor?
We have a color grading node and a color node,
adding a LUT node will make it possible to render the "final" image without going to Photoshop.
P.S. 2020.2 is awesome!
OCIO sRGB
System:
I have been playing with flakes OSL. I noticed the OSL flakes node from LiveDB is different from Octane C4D node... it hasn't got the project pin and the sliders has different maximun limit inputs. Are they supposed to be different? By the way, Live DB version works better.
Best regards,
Best regards,
- eyeonestudio
- Contact:
There is a problem with Slave Daemon. (Double Checked Firewall, License)
At the beginning of Net-Render there are 3 slaves. Only 1 left after a while.
