Cinema4D version 2020.2-RC5 (Release candicate) 23.12.2020
Mikla
As you can see the c4d status bar indicates remaining cspp but you cannot see the octane status bar overlay on the render. Also I realised the Picture Viewer doesnt update the progress of the render. You see the rendered image after its complete. This is a different issue than my previously reported bug with black screen and no results in picture viewer. (not all the passes requested for tonemapping are enabled denoiserThread0: CUDNN_STATUS_BAD_PARAM)
Mikla
aoktar wrote:Please change BUFFERTYPE=HDR not HDR-HALF, it's default and will fix it.
That indeed solved the status bar issue and black screen renders. It takes longer than previous stable release to render the scene though and I get this again at the end:
. Restart required
Edit: I get this error with or without Denoiser enabled.
. Restart required
what's GPUs and driver? and RTX enabled?
Mikla
Driver: 457.30 3080 and 1070ti
Mikla wrote:Driver: 457.30 3080 and 1070ti
please send me the scene if you can
lanklaf
BUG:
Channel Inverter does not work correctly for Normal maps.
System:
i7 8700K / RTX 2020 / 16GB RAM
Mikla
I'm tryıng to replicate the error with another scene as I'm not allowed to share the one I'm working on.
It's a heavy scene with lots of instances, geometry and scatter. Getting this on the console:
CUDA error 2 on device 0: out of memory
  -> failed to allocate device memory
OptiX error for device 0: [ERROR] "sbt->raygenRecord" is null
OptiX API error for device 0: Invalid value
device 0: RTX picking failed
device 0: path tracing kernel failed
The scene renders fine on previous stable. (2020 1.5)
Messages are from RTX functions. Try without it if you can't share anything
pxlntwrk
hi,
this release is highly unstable on my side.
I notice that the interactivity is very reduced the objects(obj,mat, param...) that we manipulate are not always updated in the Liveviewer.
Sometimes when we change a parameter on an object, all the cpu are loaded at 100% and we have to wait for octane to give us back control, sometimes several minutes.
All in all here's a collection of some bug reports if that helps.
ps:These concerns appear with this version 2020.2, everything works fine with 2020.1.5.
thanks
2020-2_reports.zip
(80.16 KiB) Downloaded 253 times
pxlntwrk.net
pxlntwrk wrote:hi,
thanks
I don't know what's the issue on your side BUT there is NOT ANY Changes in plugin side to cause these kind of issues. Please be more specific and tell is it for one scene or many? And give more info, what's OS/C4D versions, GPUs, RTX usage.
EDIT:
I see some logoutputs, thanks for that. I see only render failures in one log, there's nothing for error in others.
Return to “Releases”
