Hello,
On the latest free build which is 2020.1.5 - Engine v.21.14, when using primitive spheres to render some particles how do I change the material or at least the color of the particles(spheres)?
OctaneRender™ 2020.1.3 for Blender® 2.83 - new free tier!
So I got this error when I tried to switch render engine to Octane. No matter what I did, it still went to this
Started logging on 06.10.20 11:16:18
OctaneRender Prime 2020.1.5 (8010500)
Tried to access pin via an invalid ID P_UNKNOWN (0)
Tried to access null node pin
Can't read bool from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFAE958D200)
Tried to access pin via an invalid ID P_AI_LIGHT_STRENGTH (385)
Can't read float from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFAE958D200)
Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFAE958D200)
CUDA error 2 on device 0: out of memory
-> failed to allocate device memory
device 0: failed to allocate film buffer
My PC specs are
Core i7 9750H
GTX 1650 (Laptop)
16GB 2667Mhz RAM
256GB SSD
1TB HDD
My PC specs are
Core i7 9750H
GTX 1650 (Laptop)
16GB 2667Mhz RAM
256GB SSD
1TB HDD
I've installed Octane Free Tier 2020.1.3 on Linux + Server and I got "No Render-Server at address 127.0.0.1 after I did a first render test. It's a pity since the previous version Free Tier was working perfectly.
A.
Alessandro Michelazzi
Director and Founder | Aluxado , Visual Emotions
Just an update. It works but the Octane Server seems to crash a bit more than in the past. In Linux, I keep open the "System Monitor" to check that the "Octane Server" process is running to avoid the previous error message.axelts wrote:Seams to have the same problems as the other.
A.
- haroldgarcia
good hint, indeed I haven't updated drivers for half a year or longer, thx, much obligedtazdingoman wrote:I had the sane problem where it kept saying Waiting for image...haroldgarcia wrote:so, the new version: Blender_Octane_Edition_2020.1.5_21.14_stable
doesn't seem to work form me, at all
it is stack at: Rendering | Watitng for image...
also from some time each time I start Octane Server
it demands to be activated (again and again, each and every time)
it is not big deal but it is kinda annoying..
so, does anybody have similar problems
or know how to solve them?
Updating my GPU drivers fixed it for me.
- tazdingoman
tazdingoman wrote:Hello,
Lino helped me with this issue on the Facebook page of Octane Free for Blender. First of all, the problem happens when you import points/particles as alembic from another software and if they are animated. The solution is this which might not really be a solution but a work around, that works perfectly:
"Just add one vertex object and turn on Primitive sphere for it. Add a material. You can now change it and the sphere will react properly. Now parent the object to the main alembic object and turn on instancing for verts. Done!"
Wanted to help anybody if they had the same issue.
Keep rendering!!!
- Christian_03
I Have this problem.. do you have any solution brother?... thanks for you help
- haroldgarcia
Yes, I've updated the drivers and everything works like charmChristian_03 wrote:haroldgarcia wrote:so, the new version: Blender_Octane_Edition_2020.1.5_21.14_stable
Hi there! I've just downloaded plugin and server. Installed and start both. But render stucked with "Rendering - Waiting for image" message
Previous version of Octane worked well. GPU 2080Ti. RAM 128 GB.
It stuckes even on simple empty scene.
I'll be grateful for any advice. Thanx.
