Cinema4D version 2020.1.5-R4 (Obsolete stable) 17.10.2020
thodosplay998
Goldorak wrote: We are working to wrap up 2020.2 this month. We are on RC2 about to come out now, RC3 by end of week, and typically there are four RC builds before stable.
That would be great! Thanks for the info!
hellagain
Two months can't fix a denoise! Facking shit!
jianle
The issue is more complex, and it is caused by Nvidia CUDA.
The core devs have prepared 2020.1 SDK based on CUDA 11 with A100 Ampere GPUs, and everything was working perfectly.
Then Nvidia has presented Ampere RTX 30X0, but based on new CUDA 11.1, and the core devs had to rewritten everything with new 2020.2 SDK to perfectly support the new architecture.
So the issue is already fixed in latest Standalone 2020.2 Release Candidate.
But now, all plugins have to be rewritten with the new SDK, and this is taking time, but we are almost there, and 2020.2 has so many new cool features, that it worths to wait a little bit more, trust me!
Happy GPU Rendering,
ciao Beppe
Antoncromas
bepeg4d wrote:The issue is more complex, and it is caused by Nvidia CUDA.
ciao Beppe
Your competitor's engine had denoise support for 3000 cards on day one. Just saying. . .
tomsvfx
ciao Beppe
Thats because Redshift uses Optix wich is made by Nvidia, so it makes sense that by default upgrading CUDA, Optix gets upgraded automaticly, probably without doing much.
Octane on the other hand has custom made Denoiser, wich also works way better than Optix (plus Optix has a big dedicated team working on it)
thodosplay998
ciao Beppe
I'm 90% sure that Octane has the same OptiX denoiser. And no, OptiX is not updating automaticly. Nvidia gives you CUDA SDK and OptiX SDK. And to implement it takes time. And i think you are right an OTOY team took some time when working on denoiser to make it custom. Because Redshift is bad at denoising. like alot.
Goldorak
To confirm - we don't use the Optix denoiser in any way - our Spectral AI denoiser is completely custom built by us for Octane (for much higher quality), and depends on NVIDIA CuDNN (which NVIDIA initially broke with Ampere, but didn't fix until month later which is why we are only now able to get ampere support working with 2020.2).on MacOS we have the AI Denoiser working with Metal/AVX2 on Intel/AMD/Apple hardware.
mitchino
How do I install the latest version in c4d r23? I put it in the plug-ins folder, but c4d r23 wouldn't start up. So I put it in the main c4d r23 directory and it works but is showing an older version: 2020 1.5-R2.
Not sure what's going on - I'm on a mac using studio subscription.
HTK421
Reporting UI defect in drop menus in Live viewer
menu UI defect
menu UI defect
Return to “Releases”
