OctaneRender™ 2020.2 XB4
jobigoud
Here is another scene with various examples.
scatter-surface-demo.orbx
(1.83 MiB) Downloaded 338 times
The volume tool is currently limited to the built-in shapes.
Jolbertoquini
Hi Dev Team,
Great New Update, really good I was trying the scatter I realize one main thing is not working, is the node "instance range" on the scatter on surface.
Basically if I wanted to create a unique shader with a gradient node connected on the diffuse channel to be driven by the "instance range" node. actually is not working, It is really important that work with scatter to have a easy way to see color variation without create so many shaders network.
I guess is something you guys are thinking to update a fix?
Best,
JO
example case
example case
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
jobigoud
Yes, you're right. This should work on the volume tool but the surface tool doesn't produce instance IDs at the moment, we'll fix this for the next release.
Jolbertoquini
jobigoud wrote:Yes, you're right. This should work on the volume tool but the surface tool doesn't produce instance IDs at the moment, we'll fix this for the next release.
Thanks for the update and fast reply! :)
Despot
jobigoud wrote:Here is another scene with various examples.
Thanks for this, extremely helpful :)
jimho
the scatter and AOV are great,
One small issue I found,
the AOV pass has a slightly color difference with the main pass on the screen (when they should be same), I guess the AOV pass did not apply screen's color management on the viewport, because when export they are consistance in color.
Supermicro 4028GR TR2|Intel xeon E5 2697 V3| windows 10| revit 2019 |Titan V+ Quadro GV100+RTX 2080 Ti
jimho
should we be able to rearrange the sequence for the composite layers? because when we add a new layer it will come to the bottom, but sometimes we want them to be at top
linograndiotoy
Both Texture and Vertex Displacement are not working in 2020.2 XB4.
linograndiotoy
Test scene attached.
Displacement.ocs
(76.37 KiB) Downloaded 351 times
Despot
linograndiotoy wrote:Both Texture and Vertex Displacement are not working in 2020.2 XB4.
Texture Displacement is working fine for me... see attached image
