Octane Hydra | Solaris plug-in beta II [OBSOLETE]
BK
Dear Octane community,
OTOY® is proud to announce the availability of new DCC plugin OctaneRender Hydra | Solaris (V2020.1.5 - for Houdini 18.0.566 and Houdini 18.5.351) and Octane X Hydra | Solaris (PR2 for Houdini 18.0.566).
The world's fastest unbiased GPU rendering engine on CUDA and Metal now integrates completely with Houdini 18.0 Solaris.
What is Octane Hydra | Solaris?
The Octane Hydra | Solaris plugin is based on Pixar’s USD (Universal Scene Description) and Pixar’s Hydra API to empower artist workflows across look development, scene layout, lighting, and final rendering.
The Octane X PR2 release can be downloaded via Download page. Find out more about currently supported GPUs Octane X
Pixar's USD pipeline
-Installation steps-
Insert the OctaneRender® plugin folder path to the houdini.env file. Houdini®creates this file after launch it for the first time.
On Linux and macOS® systems, append a single line to enable OctaneRender®:
HOUDINI_PATH = "/path/to/octane;&"
On Windows® systems, you need to set the PATH to point to the plugin bin folder as well:
PATH = "C:/path/to/octane/bin;$PATH"
Setting this environment variable outputs any error related to loading the OctaneRender® plugin on the command line for diagnosing installation problems:
HOUDINI_DSO_ERROR = 2
- Changes since first beta -
  • Integrated the 2020.1.5 engine.
  • Added Octane Kernels support via MaterialLibrary node.
  • OctaneHydraSolaris plugin is now merged with the main OctaneRender for Houdini plugin
  • Fixed dylib crash issue on macOS
  • Fixed Gradient tool bug
  • Stability on Houdini 18.5.351 and performance improvement
-Known Issues-
- Light Linker is yet to be supported as we are investigating if we could assign the Octane light IDs internally.
Enterprise Subscription Downloads
2020.1.5.0 Houdini 18.5.351
2020.1.5.0 Houdini 18.0.597
Studio Subscription Downloads
Octane X PR2 Houdini 18.0.566
Enterprise Downloads
Happy GPU Rendering !!
Your team
OTOY
Kind Regards
bk3d
snakeboxmedia
Could we atleast get this for the latest production build?? it's I know the developemnt of this and the houdini plugin is separate but come on... this is only for a build that has huge issues, which was fixed in the daily builds and now in the latest production build. We finally got an official houdini build for it, but now we can't use both that and this in the same houdini version as either of them breaks... /sigh
the updates are looking really nice though. :)
BK
snakeboxmedia wrote:Could we atleast get this for the latest production build?? it's I know the developemnt of this and the houdini plugin is separate but come on... this is only for a build that has huge issues, which was fixed in the daily builds and now in the latest production build. We finally got an official houdini build for it, but now we can't use both that and this in the same houdini version as either of them breaks... /sigh
Hi Snakeboxmedia,
Thank you for your feedback!
We have updated the OctaneHydraSolaris plugin with H 18.0.597 build for Windows.
For, OctaneX we will update as soon as our main plugin is available.
Cheers
Kind Regards
bk3d
Aeromys
the update is very cool, I just have a question, is it possible to use the denoiser ? thanks
davidyannick_1
does it works with packages instead of houdini.env ?
BK
Aeromys wrote:the update is very cool, I just have a question, is it possible to use the denoiser ? thanks
Hi Aeromys,
Thank you for your feedback.
yes, Octane Denoiser is working however, we are still yet to add the UI for render outputs and for preview.
The workaround to extract the Denoiser pass and other Octane pass is to use Octane UI.
Please create hdOctaneScenes folder to C:\ drive and an empty txt file then name it as hdOctane.txt.
To enable the Denoiser, you will need to create geometry (sphere and set the scale to 0)> MaterialLibray node>
Inside the MaterialLibray node> you can create Octane Render Target> create Kernels, Octane pass node and Imager node to enable the Denoiser.
Hope you will find this useful !!
Cheers :)
Kind Regards
bk3d
BK
davidyannick_1 wrote:does it works with packages instead of houdini.env ?
Hi davidyannick_1,
Ah not yet as packages, it still needs to assign the path to houdini.env.
we would check if this is doable later when our plugin is a bit Octane feature complete and Stable.
Cheers
Kind Regards
bk3d
ptunstall
Is it possible to get a LINUX build of this? We're rendering an entire TV show with Houdini Octane and this would be really amazing to try out.
eyeonestudio
Any news for 18.5 Hydra?
C4D R2025 / Win11 / AMD TR WX Series / 256Gb RAM / RTX3090 / 100GbE
BK
ptunstall wrote:Is it possible to get a LINUX build of this? We're rendering an entire TV show with Houdini Octane and this would be really amazing to try out.
Hi Ptunstall,
Thank you for the post.
Sorry, we are currently planning to implement a few more important Octane features perhaps we may consider builds for LINUX platform after that.
Also, as you know already the windows builds are still beta so we do not recommend using it for production.
Anyway really excited to hear about the TV show!! xd
cheers
Kind Regards
bk3d
Return to “Releases”
