Is it possible to utilize Octane Network Rendering with OctaneRender for Unity?
If so, what would the licensing requirements be?
Network rendering
Moderator: ChrisHekman
- ChrisHekman
Network rendering should work through the OctaneGUI interface.
It requires a enterprise licence.
- james_conkle
- Contact:
Sorry to hijack this but I had a network rendering question that I can't answer myself since I have a studio subscription for the next few months... Anyways if I have an enterprise and node license can I network the two PC with a single ethernet cable? Will that be as fast as going through a network switch or router?
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
- ChrisHekman
Depends on the speed of your network switch or router. If they are faster than the ethernet adaptors on your pc's, then it wont really matter.james_conkle wrote:Sorry to hijack this but I had a network rendering question that I can't answer myself since I have a studio subscription for the next few months... Anyways if I have an enterprise and node license can I network the two PC with a single ethernet cable? Will that be as fast as going through a network switch or router?
- james_conkle
- Contact:
Thanks for the clarification that makes sense. Right now everything is on wifi (which I bet is no good for Octane Network) but the PCs have 10gb Ethernet ports and are right next to each other. It sounds like any networking I learn will be able to be utilized by Octane which is helpful but intimidating
Thank you for the answer.ChrisHekman wrote:Network rendering should work through the OctaneGUI interface.
Just to be clear, this means that the OctaneRender® Enterprise Subscription would be sufficient to enable the Network Rendering feature inside the Octane for Unity plugin.
There would be no need for a separate OctaneRender Creator for Unity subscription alongside the Enterprise subscription?
I assume that for each additional render node, an OctaneRender® Enterprise Render Node subscription is required as well?
