Cinema4D version 2020.1.5-R4 (Obsolete stable) 17.10.2020
nibbler
Is Multi-Platform Network Rendering with 2020.1.5 Clients and Octane X Master allready integrated?
Thanks for feedback ;)
Several MacPros + Win PC • Cinema 4d • Octane Mac & Octane Win
nibbler wrote:Is Multi-Platform Network Rendering with 2020.1.5 Clients and Octane X Master allready integrated?
Not yet, technically Octane 2020.1.5 is based on v8 SDK, while OctaneX is based on v10 SDK, so we need some more development before they will be both on the same SDK level for Network rendering.
Stay tuned!
ciao Beppe
bottom
Hi there,
Does the latest version work in C4d R23?
Many thanks
Stuart
Kalua
bottom wrote:Hi there,
Many thanks
Stuart
Read first post.
Octane User since V1 Beta
Published the new builds(R4) over R3.
Changes of 2020.1.5-R4 plugin
- Matrix object support with Scatter Object
- More motion blur accuracy on export orbx, support for "time sampling per frames" parameter
- Hide/Show option for LV icons
VVG
aoktar wrote:Published the new builds(R4) over R3.
1.When will Neutron (node-based sys) be supported R23?
2.When will C4D XB 2020.2 ?
thanks
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
pxlntwrk
thanks for udpdate,
just to point out that there are 2 "Reset" slots in the new menu.
And also can you tell us about the functions of the "Octane Menu" and "Octane Icons" slots of this new menu, because here so far, they don't seem to have any effect ?
pxlntwrk.net
eyeonestudio
S22 : File Menu - String Not Found
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
divasoft
Hi Ahmet, i found a new bug, please take a look.
https://yadi.sk/i/BUeetDn2PRDkIw
divasoft
I also noticed that in some cases octane cannot exit solo mode material. Nothing helps. We have to restore scenes from a backup. And if there is no copy, then the whole work will be ruined.
Return to “Releases”
