Hi Paul
I have a problem with camera motion blur.
I have scene with replicators and a terrain with displacement map. Camera motion is fast.
Some of the frames have no motion blur. Looks like its random frames. Is this a bug or is there a work around?
Using Modo 14.1v1 and octane 2020.1 (8010000). And I am rendering inside of Modo and not in Octane Standalone.
Andras
http://www.checkpointvfx.com
Motion Blur missing in some frames
Hi
I am not aware of an issues that would cause this. Which version of the plugin are you using please? Do you have a sample scene which exhibits this issue that you can send me?
Hi Paul
sorry for the long delay. Just in the midst of projects.
I have attached 2 Modo scenes.
Modo 14.1v1 using Modo plugin Enterpise 2020.1.4.162
MotionBlur_Replicators ( a plane emitting particles and the Replicator is replicating the teapot on the plane)
MotionBlur_NoReplicators ( in this scene the Replicator teapots are "frozen" ...now the scene is not using Replicators)
In both cases the Camera is animated and Camera motionblur is on.
When I render the scenes some of the frames don't have motionblur.
First I thought it might be Replicator problems but the missing motionblur also happens in the scene that is not using Replicators.
I have attached both scenes
- MotionBlur_Replicators.zip
- MotionBlur_Replicators and NoReplicators
- (156.62 KiB) Downloaded 190 times
I have referred this issue to OTOY. I will let you know once I get a solution.
This is now fixed in release 2020.1.5.163
Hi Paul
I have downloaded 2020.1.5.163
Tested with the scene I provided you. It works. All frames have motion blur.
I will do more tests with other scenes and report back if I run in to any issues.
Thanks for the quick fix.
Andras
Andras
