OctaneRender™ 2020.2 (XB1) is out! + 2021 roadmap updates!
Elvissuperstar007
Built-in multi-light, fast fog, wireframe and custom compositing node graph passes
I can't find where it is. you hid it so not intuitively
https://www.youtube.com/watch?v=At-IdZE ... e=emb_logo
I don't understand why not make it easier like Corona - Vray
I searched for an hour and did not find
Elvissuperstar007
OpenColorIO color management
this should also be built-in or at startup, I never found the link where to download it, if I did not find it, then ordinary users will definitely not find the site there, which is not very informative
The standard ACES OCIO config can be downloaded from here.
Here's an example of the different looks that can be applied to an image using the Filmic Blender OCIO config:
where is the download button on this site?
wallace
funk wrote:Thanks team. This is looking like a great release. I've been loading some older scenes and noticed some issue:
1. OTOY's sample SSS scene from the 2020.1 thread loads with a "null material" and crashes on render:
https://render.otoy.com/downloads/36/b0 ... adius.orbx
NOTE: This null material also appears in the right click > materials menu
Thanks for your report, it's expected to load as null material now whenever an older scene with specular material with 1.0 IOR and 0.0 roughness is loaded.
This is because we have to keep specular material as a material to respect the IOR stack while null material would always make the material behave as "pure volume".
As to why it crashes, I will investigate a bit deeper into this and provide a fix.
davidyannick_1
I thought 2020.2 production build was planned for this summer ? isn't it ?
jimho
fast fog as post means it would not help on the god ray, I guess, right?
Supermicro 4028GR TR2|Intel xeon E5 2697 V3| windows 10| revit 2019 |Titan V+ Quadro GV100+RTX 2080 Ti
karl
Elvissuperstar007 wrote:OpenColorIO color management
We can't really make an OCIO config built-in, because we don't know which OCIO config you would like to use. Those links are just suggestions - the ACES OCIO config in particular is a "catch-all" that seems to be intended as a starting point for an organisation to develop their own OCIO workflow using ACES, rather than something to take and start using directly. However, it's still useful for trying out an ACES workflow, even though the sheer number of color spaces it contains is a little overwhelming.
GitHub seems to only provide a download link at the top-level of a repository, so you'll have to grab a ZIP file with all the different ACES versions together (suggest using the newest version, 1.0.3). This is available at https://github.com/imageworks/OpenColor ... master.zip (the link in the original post has been updated).
Goldorak
davidyannick_1 wrote:I thought 2020.2 production build was planned for this summer ? isn't it ?
We planned a release for August, but Ampere tuning pushed this out, but it’s worth it. Crazy speeds on 2020.1.5 on 30x0... and will be even faster with 2020.2+ as we optimize RTX even more from here.
Goldorak
jimho wrote:fast fog as post means it would not help on the god ray, I guess, right?
Correct, it’s just using depth/pos to do a ‘mist’ attenuation pass. We are working on real time GR and have great results in brigade: https://twitter.com/otoy/status/1303018 ... 79296?s=21
funk
Thanks for the extra info on the null material. It makes sense, but this is going to cause issues for plugins, where its not so easy to swap out pre-existing nodes
funk
karu wrote:GitHub seems to only provide a download link at the top-level of a repository, so you'll have to grab a ZIP file with all the different ACES versions together (suggest using the newest version, 1.0.3).
Apparently 1.0.3 is old (according to a friend who uses ACES) and he suggested using this instead (ACES 1.2):
https://github.com/colour-science/OpenColorIO-Configs
I wasnt sure how "official" this was, but I see its also linked to from the OCIO docs here:
https://opencolorio.readthedocs.io/en/l ... 1.0.3.html
Return to “Commercial Product News & Releases (Download here)”
