Render Error Too Many Nodes?
DustinM
Im trying out Octane but I think my scene ios too big for it. Here's the log:
Started logging on 07.09.20 01:23:05
OctaneRender Demo 2020.1 (8010000)
Tried to access null node
Too many nodes
CUDA error 719 on device 0: unspecified launch failure
-> failed to wait for event
device 0: path tracing kernel failed
-> failed to destroy CUDA event
-> failed to deallocate device memory
-> could not get memory info
-> failed to deallocate pinned memory
-> failed to deallocate device array
-> failed to destroy texture objects
-> failed to unload module
you are using an old demo version, now we are at 2020.1.5.
Are you using Standalone or an integrated plugin?
Please, also download and run GPU-Z:
https://www.techpowerup.com/gpuz/
And share a screenshot from the Graphics Card tab, for all the available Nvidia GPUs, thanks:
ciao Beppe
DustinM
Its the demo version that I just downloaded from the website last night. Do you have a link for the new version? Found it, got it. Will try it.
DustinM
I do get an error now but it just sits there wit ha black screen in the VFB and no progress in the progress bar indicator. I read that I dont need the matching standalone for the plugin also.
Local DB is not supported by this build
Trying to set array in attribute of wrong type
Too many floats
Too many nodes
Which plugin are you using exactly?
From the log, it seems that you have tried to use the LocalDB, but the demo version cannot save, so LocalDB is not available.
ciao Beppe
DustinM
The Local DB entry was me accidentally hitting the button apparently. Wouldn't be an issue for me. Plugins Im using are Phoenix FD and Forest Pack. Ive tried hiding the Forest Pack items but I still get the error.
Ok, so you are using Octane for 3ds Max, correct?
Could you share some screenshots?
ciao Beppe
DustinM
Will do, thanks. It's a fairly large scene with Forest Pack, and Phoenix FD with both fire, smoke, and water elements. What type of screenshots do you need?
DustinM
It seems its something in my scene, Ive isolated a few hero objects and its working fine. Ill add back to the scene little by little until it errors again.
