Can someone tell me what this means. Getting an instant crash doing an ipr of a scene.
00:00:20 (0020.80) | [profile] Function "GetPreviewImage" over "" execution time: 0.001 seconds
00:00:20 (0020.99) * OCTANE API MSG: CUDA error 700 on device 1: an illegal memory access was encountered
00:00:20 (0020.99) * OCTANE API MSG: -> failed to launch kernel(kernel27)
00:00:20 (0020.99) * OCTANE API MSG: device 1: path tracing kernel failed
00:00:20 (0020.99) |
00:00:20 (0020.99) | ++++++++++++++++++++++++++
00:00:20 (0020.99) | +++ IPR RENDER FAILURE +++ processing the failure callback
00:00:20 (0020.99) | IPR: reset image callback
00:00:20 (0020.99) | IPR: wait for the getPreviewImage function
00:00:20 (0021.00) * OCTANE API MSG: CUDA error 700 on device 0: an illegal memory access was encountered
00:00:20 (0021.00) * OCTANE API MSG: -> failed to download symbol(stats data)
00:00:20 (0021.00) * OCTANE API MSG: device 0: path tracing kernel failed
00:00:21 (0021.09) | IPR: free the OpenGL buffers
00:00:21 (0021.09) | IPR: rendering done
00:01:14 (0074.62) | IPR: close the IPR preview window
00:01:14 (0074.62) | IPR: finish render thread command
00:01:14 (0074.62) | IPR: abort render thread command
Error log, what does this mean?
What plugin version are you using? If you can share the scene I could take a look at it here, and verify if this problem is fixed in the latest Octane 2020.1.5 core, that I'll include in the next plugin build early next week.
Commercial project Juanjo, so can't share and I am using the latest build of core and plugin. The annoying thing is that if I run ipr on the first frame it gives me a preview no problem but as soon as I try to do an ipr of any other frame it immediately crashes.
