rail clone instance engine support
Sub forum for feature requests etc
coilbook
paride4331 wrote:
mbetke wrote:Can I use Railclone 4 like I use Forest Pack Pro? It seems the RC instances are working different.
Hi mbetke,
yes, it work, you can find RC option in Render setup > support.
Hi Paride,
It doesn't work for me. Rail Clone uses a lot of vram like instance doesnt work the way it works in itoo forest. We created highway rail guards 4 miles long and it uses 300 mb of vram. Too much for instanced objects. Can you look at it? Thanks
paride4331
Hi coilbook,
I had a 4 mile rail guard, it eats about 74 Mb.
Do I something different from you?
mbetke
This is funny. I also tested with 10 instanced trees. 10Mio polies.
All trees just copied as an instance need exactly the same VRAM/RAM than an RC object with ten trees. I use point cloud for display.
Seems to work fine.
In old versions the RC point cloud turned to a mesh in viewport as soon as I pressed render. It used a lot of ram too.
I will now test doing hedges with RC again.
PURE3D Visualisierungen
Return to “User Requests”
