Hair thickness not working?
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
sdanaher
The thickness sliders seems to do nothing in the object Params. Hair is always super thin. H18, 2020.1.4
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
juanjgon
These parameters only work if the object doesn't have a "width" attribute. This attribute always overrides any other hair thickness parameter configured at the OBJ level.
sdanaher
juanjgon wrote:These parameters only work if the object doesn't have a "width" attribute. This attribute always overrides any other hair thickness parameter configured at the OBJ level.
OK, that makes sense. I see its created by the hairgen node where it can be changed or deleted, but its then modified by vellumsolver which always resets it to a tiny value. So you have to use attribute delete correct?
juanjgon
Yes, you need to delete this attribute using the attribute delete SOP.
Return to “Bug Reports”
