I tried everything, different software for uncompressing, removing bug reports.
Thank you
Octane C4D v2020.1.4 Block the C4D on loading screen
- alexbeslin
- alexbeslin
Definitely is something wrong with a v2020.1.4 for C4D
Or you didn't delete the unused plugins from c4doctanealexbeslin wrote:Definitely is something wrong with a v2020.1.4 for C4D
- alexbeslin
Unfortunately, I did.aoktar wrote:Or you didn't delete the unused plugins from c4doctanealexbeslin wrote:Definitely is something wrong with a v2020.1.4 for C4D
It's the only reason for this behavior
- alexbeslin
To be honest, I run out of options, v2020.1.3-R2 is working fine.aoktar wrote:It's the only reason for this behavior
- jayroth2020
Hi Alex, please send in a report and scene file to help at otoy dot com.
Thank you!
Thank you!
- alexbeslin
jayroth2020 wrote:Hi Alex, please send in a report and scene file to help at otoy dot com.
Thank you!
I cant, the C4D freeze on the loading screen, while loading plugins (soon as I remove Octane 1.4 C4D load fine). I tried a few more times to install it and the same result.
- jayroth2020
Please submit a bug report regardless so that we can get this sorted out for you ASAP. Our help system is more efficient than the forum.
Thank you!
Thank you!
