World Machine displacement edge artifacts
mikeadamwood
My workflow is export the model from World Machine as a mesh .obj then use the normal map to fake the finer detail.
Windows 11 Pro | ASUS Pro WSX80E | AMD Threadripper Pro 5975WX 32-Core | 256GB Micron 8x32GB 3200MHz ECC | 2x PNY RTX6000 ADA
thomastraum
I am having the same problem. Has anyone found a real fix for this? Not a workaround.
FxDesign
Same problem here :(
fivebythree
If you are able to make the displacement map seamless it should slice the edge perfectly.
This is at least the way it works in World Creator.
STANDALONE+STUDIO WIN11PRO | RTX3090 | XEON 4210 20 CORE | 96GBRam
jayroth2020
Best to submit the issue to help at otoy dot com with some files for testing.
