I used Octane 2019 to do a project but when I send it to a render farm which is Octane 2020 the render stucks and only render the first frame.
How can I make my scene work in 2020?
Thanks in advance
Octane 2019 to 2020 (render stuck)
Better information would be great to help you!
Can you render the scene in your pc?
Delete some materials until it work. It's for detecting what causes this. Probably you have c4d shaders
1-Check for errors in CONSOLE window
2-Apply same procedure if you don't see any errors.
- jayroth2020
@Malaco, if, after following Ahmet's recommendations, you still can't make it work, please file a report: help at otoy dot com
Thank you.
Thank you.
Here's a trick that often works for these sorts of problems:Malaco wrote:I installed 2020 in my PC and I got the same problem, render stucks on frame 01.
I then downgrade to 2019 and it works flawlessly
Start with a new, empty 2020 project and use "Merge Project" to add the 2019 scene to it.
If that doesn't work:
Start with a new, empty 2020 project. Open the 2019 project, select all, then copy/paste the entire contents into the 2020 scene.
Great! But this is still a mystery why happen. Could you be kind enough to share your scene for testing, please?Malaco wrote:@frakmci tricks actually fixed my problem. The Merge Project works perfectly.
Thank you sir
