hi there,
if i export my c4d project as orbx, are the cameras exported as well?
i have an orbx file in unreal open, see the character and the landscape environment, but can't find my c4d camera...
is there a trick? where can i find it?
orbx from c4d: animated camera is missing...
Moderator: ChrisHekman
http://www.larsnaglerworks.com
http://www.behance.net/LarsNagler
http://cargocollective.com/larsnaglerworks
Mac Pro 5.1 :: 3,33 GHz 6-Core Intel Xeon :: Mac Pro Nvidia GTX680 4 Gig :: 32GB :: C4D 13 Studio :: Octane Renderer
OP-1
OP-1
- ChrisHekman
You can extract the rendertargets from the Orbx by dragging the orbx into your scene. Select new the OctaneOrbxActor and press ExtractRenderTarget
I did that so that my character and also the surroundings became visible.
but the camera defined in c4d is not available in the object manager...
or must everything be extracted individually by target from the orbx...?
OP-1
OP-1
- ChrisHekman
lassinger wrote:I did that so that my character and also the surroundings became visible.
There is currently no camera extraction and conversion to unreal cameras. Neither for the extract rendertargets feature, or the orbx importer that converts to unreal.
Ill check if this would be possible.
ok, thank you!
i hope there is a solution to bring a c4d camera to unreal engine...
ChrisHekman wrote:lassinger wrote:I did that so that my character and also the surroundings became visible.
OP-1
OP-1
- ChrisHekman
lassinger wrote:ok, thank you!
What do you want to use the C4D camera for? Does it contain animations?
yes, i wish to have my animated (octane)-cameras from c4d in unreal via Orbx...
at best with the exact adoption of all parameters (dof settings for example)
OP-1
OP-1
- ChrisHekman
It might be possible to add a way to use the rendertargets inside an ORBX proxy, including their animation data.
The other ORBX importing option that converts to unreal components, does not support animation atm. Its on the list, but it has a lower priority.
ok, thank you very much...
ChrisHekman wrote:It might be possible to add a way to use the rendertargets inside an ORBX proxy, including their animation data.
OP-1
OP-1
