Daylight models ground color?
kirk
Why I see nothing setting any color there? I need to have something resembling ground for proper color bleeding and light bouncing while I use ground plane as a shadow catcher
Q6600, 5GB ram, GF9800gt-1gb, 3dsMax 2008 , Blender , Zbrush, Messiah 3d v5, Terragen 2, Vue 6 Infinity
frankmci
The default Ground Start Angle is 90, or basically, directly down and therefore non-existent. Set it to 0 and it will go right to the horizon.
kirk
frankmci wrote:The default Ground Start Angle is 90, or basically, directly down and therefore non-existent. Set it to 0 and it will go right to the horizon.
Thank you frankmci . It seams not working with Preetham Daylight Model I like. But works with others
frankmci
You might check to see if that daylight model even supports ground color. If it does, but isn't showing up in Octane, I'd report it as a core bug.
