When the interactive rendering is switched, it is stuck and
Unreal® Engine Integrated Plugin
Moderator: ChrisHekman
ChrisHekman
Could you try export the unreal scene to ORBX and send me the ORBX file?
Or steps how to reproduce the bug?
@TBModel
What is that actor with 2087 instances? It is named 039?
gfxtramp
Steps to produce are open the UE4 project and render. If I open a second "Level" (which is basically a room within the yacht) its fine. I cannot send any files due to NDA. The screen shots sent previously by OP match my setup.
ChrisHekman
gfxtramp wrote:Steps to produce are open the UE4 project and render. If I open a second "Level" (which is basically a room within the yacht) its fine. I cannot send any files due to NDA. The screen shots sent previously by OP match my setup.
So you are always getting a hang with any scene when you ahve interactive rendering switched on?
Return to “Unreal® Engine”
