OctaneRender® for 3ds max® v2020.1.3 - 10.12
samsue
Hi, we need another slave build?
samsue
Would it be possible for you to choose a folder and thus exchange between different Luts more easily? Like the Response menu?
would be so cool
paride4331
samsue wrote:Hi, we need another slave build?
Hi samsue,
you would install Octane slave node 2020.1.3 (8010300).
paride4331
mbetke wrote:Can someone explain the new volume spotlight a bit?
Are my System Units important? I use 1 Unit = Centimeters for ages. Depending on the scene I change Display Unit Size to cm or m.
I see in some samples scenes from paride that the System Units are set in meters.
Hi mbetke,
you can use the unit you prefer, keep in mind Octane think in meter, then in Octane nodes 1 is 1mt.
samsue
Hi samsue,
yes, i have OctaneRender Enterprise 2020.1 (8010000)
stop works after update to 2020.1.3 - 10.12 from 10.11
acc24ex
HHbomb wrote:Hi. I have a problem with Vol_spotlight. See pic.
Volume effect is done on intersection of spotlight cone and wall.
Nice and very fast effect nevertheless !
it seems that volumetric spotlight works like a geometry with light projected through it, yeah geometry doesn't really obsure light.. is this how it was implemented?
While I was waiting for this feature I started using blender in the meanwhile :)
Tharso
Hi! I cant complete the orbx export ! I receive a message ( Failed to create camera with m_PreExportNoCameraScript )
last version plugin and max 2021
mbetke
When render viewport is open and I modify stuff, then sometimes surfaces with displacement get switched off. Like a wall who is suddenly gone. Need to close and open window.
PURE3D Visualisierungen
Sidches
mbetke wrote:When render viewport is open and I modify stuff, then sometimes surfaces with displacement get switched off. Like a wall who is suddenly gone. Need to close and open window.
I saw this bug today in my final renderer, the first frame is right, and then the object just disappears.
paride4331
Tharso wrote:Hi! I cant complete the orbx export ! I receive a message ( Failed to create camera with m_PreExportNoCameraScript )
Hi Tharso,
With no Octane camera, did you check "enable temporary camera for export" option in Octane Global preference panel?
Return to “Releases”
