I've started a new topic with a good example
viewtopic.php?f=87&t=56039
							python and settings
code is not working now.where can I found the 'myOctaneSettings' obj?
I found some script from the forum, but I can't change the value.
or How can I set it? so that when I open c4d, auto change setting to my preset.
ID_OCTANE_LIVEPLUGIN = 1029499
def main():
    d=doc.GetDataInstance()
    bc=d.GetContainer(ID_OCTANE_LIVEPLUGIN)
    bc.SetData(3001, 0)    #this is not working
    print bc
    print "Octane version=",bc[c4d.SET_OCTANE_VERSION]
    print "Lock resolution=", bc[c4d.SET_LOCKRES]
    print "Check camera updates=", bc[c4d.SET_CHECK_CAMERA]
    print "Default environment color=", bc[c4d.SET_DEF_ENV_COLOR]
    print "DL Max samples=", bc[c4d.SET_DIRECT_MAXSAMPLES]
    print "Kernel tip=", bc[c4d.SET_KERNEL_TYPE]
    print "PT Max samples=", bc[c4d.SET_PATHTRACE_MAXSAMPLES]
    #bc[c4d.SET_KERNEL_TYPE]=1#not working
    c4d.EventAdd()
if __name__=='__main__':
    main()
    c4d.EventAdd()
