does anyone have experience with the Q Tile Pro plugin (https://qucumber.at/q-tilepro/) used with Octane?
This plugin promises to be kind of a magical problem solver but does it do it's job even within an Octane environment?
Thanks for any feedback!
Ron
Q Tile Pro - any experience?
I would also like to know. It is supposed to automatically bake textures to work with Redshift and Octane.
https://www.youtube.com/watch?v=cb5Txsypn0g
C4D 2025.1.1 Octane v1.9 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
- stefan_laub
Hi Ron, Hi Kalua,
as in any gpu engine you use Q-TILE-PRO tile shaders resulting pixels, as bitmap.
the baked result is 1:1 the same as the shader would render at that res. we usually use 4 or 8k results. sometimes 16k.
there are 2 ways to make that:
1) octanes internal baker (this is pretty good and fast and works usually fine for setting up a shader/material, or resolutions up to 2-4k
2) using the Q-TILE-PRO baker, and use the q-tilepro bitmap inside a octane bitmap node, this is good for any high res, and has the advantage that the thing needs to be baked only 1x.
for final rendering i recommend this (i use it that way in all apps that not support direct c4d shaders)
the Q-TILE-PRO internal baker is fully multi threaded and very fast also for 8k texture or higher. any change you can update then in the shader on on click on the bake button, all bitmaps where you have loaded the result update with ti automatic.
on redshift the internal RS baker is too slow and sluggish sadly, there i use all time the Q-TILE-PRO bake button.
you can ask us questions direct at [email protected]
cheers
Stefan Laub
3dtools.info
qucumber.at
cheers
Stefan Laub
3dtools.info
qucumber.at
Thank you, Stefan.stefan_laub wrote:Hi Ron, Hi Kalua,
cheers
Stefan Laub
3dtools.info
qucumber.at
