Archive/ export ORBX and abc
Sorry, I thought I did attach the file to the post.
- export_frame_range_empty_01.rar
- (46.18 KiB) Downloaded 168 times
Hmm, it is true. The plugin doesn't finalize the .orbx file while exporting animations. I'll investigate this issue ASAP, it can be a bug in the latest builds. The orbx export from single frames seems to work fine.
It is funny. This problem only happens if you export 24 frames. If you export any other number of frames (for example 23 or 25) all works fine. While investigating why this happens, the workaround is to try to avoid exporting proxy files with this number of frames.
