External OSL Texture needs recompiling on doc load
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
pegot
I see that in latest version of Octane Blender (2020.1 21.7) the issue with the disappearing input pins on OSL Text nodes has been fixed. However, I still have to recompile the script each time I load the file again. Is that normal? Do external OSL scripts always have to be recompiled each time the file is open?
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
pegot
I also just took the same external script and wrote it into the OSL node as an internal script - but it still needs recompiling on every new document load after closing Blender.
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
linograndiotoy
pegot wrote:I also just took the same external script and wrote it into the OSL node as an internal script - but it still needs recompiling on every new document load after closing Blender.
OSL nodes get compiled when you start the preview or a render.
pegot
linograndiotoy wrote:OSL nodes get compiled when you start the preview or a render.
That's not happening with my set up. I'm using the OSL blur shader. And I have to recompile it every time I close Bender and then upon that file again. Maybe the blur code is different than other OSL textures that causes this?
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
linograndiotoy
Can you please share a simple scene showing the issue? Thanks!
pegot
Ok. See attached blend file. The OSL node is part of the environment texture. It blurs a procedural texture.
OSL-Compile-Issue.zip
(514.35 KiB) Downloaded 171 times
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
linograndiotoy
I've tried the scene in the current internal build. OSL nodes are compiled correctly, but the whole scene doesn't render on my system. We'll take a deeper look.
pegot
This appears fixed with the latest 21.8 release. Thanks!
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
linograndiotoy
You're welcome!
Return to “Bug Reports”
