I got it to work fine with the Tyflow particles from that article, but the same article doesn't say anything about the tyCache use. So the article doesn't seem to apply in this case.paride4331 wrote:viewtopic.php?f=27&t=74783tcheng00 wrote:Hey guys,
I exported my tyflow particles and loaded it back in using the Tyflow Cache. However, i'm not sure how to get it to render. I Enable Particle Interface on the Tycache, but that didn't seem to work. Is it supported at this time or did I miss something? Thanks.
OctaneRender® for 3ds max® v2020.1 - 10.11
Well okay for the groups and a bit bitter if I can't use 3dsmax stock scene management features. Stuff like grouping and containers.
What's about Xref? The larger the scene the more likely I use xref objects.
They are kind of groups too.
PURE3D Visualisierungen
- paride4331
Hi mbetke,mbetke wrote:Well okay for the groups and a bit bitter if I can't use 3dsmax stock scene management features. Stuff like grouping and containers.
you can group, what I meant to say is if you make a big groups will not help; the management of VRAM and Ram resources will work worse and slower.
A rough example to understand:
Case (A)
Available VRAM is 7GB
Out-of-core available is 8GB
scene is 9GB in a 9GB single object groups
in this case the scene will not be able to use neither VRAM that Ram and will have a render failure.
Case (B)
scene is 9GB in a 5GB + 4GB object groups
in this case the scene will use 5GB VRAM than 4GB Ram.
Case (C)
scene is 9GB in a 3 x 3GB object groups
in this case the scene will use 6GB VRAM than 3GB Ram.
Case (D)
scene is 9GB in a 9 x 1GB object groups
in this case the scene will use 7GB VRAM than 2GB Ram.
In All of these cases I have not considered the textures and adding new geometry and textures during the workflow.
This workflow therefore continuously moves gemotries and textures. Smaller packages (like small object groups) will move faster and optimize VRAM and Ram better than a single package.
Said that, then we have to consider rendering (static and animation) if and what to set to movable proxy.
Basically I set everything to movable proxy during the workflow setting scene.
Thank you for the explanation. I'll start using Layers more often. In the meantime, Is there a way to request a feature to ungroup everything before it renders for better memory optimization. Obviously, grouping causes large memory chucks and therefore isn't packing the Vram as efficiently? The same goes for movable proxies. Can we have a feature to auto-set these values based on keyframe or deformation detection right before final rendering? Having to manually manage each item on a big scene can be difficult to do. I assume most people just leave it set to movable proxies and don't unset them when they do final render. Perhaps we need a preview work mode (sets all items to movable proxies) and a final render mode (remove movable proxies on items with no keyframe)?
- paride4331
Oh wow, from reading that, it seems that Movable proxy should always be on and there's no advantage of having anything set to non-movable proxy?
Looks like I just needed a tymesher set to input geometry mode for it to work. Not sure if that means all my instance geometry becomes unique.Sidches wrote:Hey tcheng00, try to mark this item, save the project and reopen it.
Hi Paride,
please fix old volume behavior. It still makes phoenix fd smoke almost black in AO mode
Also you cannot have white smoke anymore. It has a lot of black because the rays dont penetrate it well. Old versions didnt have it
I think bug is when using diffuse/ao, PAthtracing has nice white smoke
It looks like pathtracing has scatter depth and diffuse kernel doesnt. Can devs add it?
THanks
THanks
