Error message says :
Plugin 'OctanePlugin' failed to load because module 'OctanePlugin' could not be loaded.
There may be an OS error or the module may not be properly setup.
It picked up UE installation and completed installing, but not able to launch Unreal Editor due to the error unless I delete the Octane from Plugins folder.
Is there a step I missed after running installer?
Thanks in advance
Unable to launch Octane Plugin on UE 4.24.3
Moderator: ChrisHekman
- ChrisHekman
No it should just work™.
Two thinks you can try:
- reinstall. (Make sure unreal is closed when installing)
- Download Octane for Unreal 0.35. It was complied explicitly with the 4.24.3 unreal version.
I have exactly the same problem with Unreal Engine 4.26.1 on osX 11.2.3. Is there a solution to this? Also Somebody at Otoy might want to complain to Apple because the files downloaded from Otoy are "unable to be verified to be malware free" by Apple which I think is crazy beyond belief!!!!
