Straight Alpha problem in PV
Sub forum for help and tutorials.
sdanaher
Having an issue with Straight Alpha, especially with DOF blur against a bright background (eg Sky).
During rendering the object edges are treated correctly, but on completion the background environment is suddenly mixed in with the object edge as if Keep Environment is turned on (its off). This results in a halo on object edges when compositing with the alpha.
You can kill the render before it completes and retain the correct edges without those background pixels mixed in. But if it completes they get applied. Happens when rendering to the PV only. LV doesn't seem to have this issue. Oddly, if you check 'Keep Environment' with straight alpha you get double brightness at the edges - as if the environment is being added twice.
Is there a setting hidden somewhere other than the 'Keep Environment' in the Kernel? I have Alpha and Straight Alpha checked in render settings. Denoising is Off. Render Passes are off. sRGB, Tonemapped.
2020.1-RC3, R20.
If you stop it before finishing it is correct:
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
sdanaher
Thought for a moment I found a solution with 'Disable partial alpha', which fixes the background brightness being added to the edges, but it no longer stores the edge transparency in the alpha channel.
still need a workarround
what about the Keep Environment option in Kernel settings?
If enabled, try to disable it.
ciao Beppe
sdanaher
bepeg4d wrote:Hi,
ciao Beppe
Hi Beppe. That is already disabled - its right next to the Alpha Channel button, not easy to miss ;)
If its not something obvious like that, its seems like this could be a real problem.
sdanaher
PMd
Return to “Help / Tutorials”
