Surface Material Filter Not working.
Moderator: BK
rajib
UHF wrote:Rajib. Its not hair. Its V4 colliding with the same V4.
Ah. Sorry, did not notice that.... The line in the forehead I get is generally due to the hair colliding with the head and in any case this happens whenever 2 geometry intersect and expanding one of them so that they don't collide kind of works most of the time. . hmmm... If you can select the Eyebrow mesh of V4 , under the Parameters Tab under the Eyebrow mesh do you see General->OctaneRender ? In that if you change OctaneRender:Visibility control to 0 does it help ?
If possible can you put a screen shot of the scene and parameters tab with the V4 eyebrow selected ? I don't have V4 so unable to check.
Windows 10 Pro i9-9980XE 128GB RAM|4 x Titan RTX
Houdini 18.5(2020.2.1.2)|Cinema C4D R26|Daz Studio Pro 4.21.0.5(Octane 2021.1.6.83)
NVIDIA 460.89 Studio Standard
Zay
Rajib, the eyebrow mesh is loaded even though if you tick the mesh off in the Scene Panel. So there's nothing you can do other than trying to move the mesh out of sight. Octane will render it even if it is hidden for the camera or setting opacity to 0.
To me this is a serious bug as only god knows what else is loaded in a scene that shouldn't be there. Doesn't matter what you do as Octane will render it even if you hide it or not which also affect the rendering speed. Even more so if you try to scale objects down and move it out of the way. Found that out the hard way.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
rajib
Zay wrote:Rajib, the eyebrow mesh is loaded even though if you tick the mesh off in the Scene Panel. So there's nothing you can do other than trying to move the mesh out of sight. Octane will render it even if it is hidden for the camera or setting opacity to 0.
Ok, I downloaded V4.2 and made a render.
V4.2 base character render
Does this look to you ? There are no artifacts in the forehead. If this is okay, basically under Surfaces Material Filter remove everything and render. No need to set any opacity to 0 etc. Default Visible off works.
rajib
With the Surfaces Material Filter empty, lets say you enable the visibility of the 1_Eyebrow and lets say color is set to red. This is what I get :
1_Eyebrow visible, Opacity 1, Red Diffuse
Now if I set the Opacity to 0 in the material, there is no eyebrow mesh shown
1_Eyebrow visible, Opacity 0, Red Diffuse
So basically keep the Surfaces Material Filter empty:
Surface Material Filter should be empty
That way whether the 1_Eyebrow has visibility off in the scene tab / Visibility is on but Opacity is 0, it will not create the artifact in the forehead.
Hope this helps.
Regards,
Rajib
Zay
rajib wrote:Ok, I downloaded V4.2 and made a render...
Great. So now you need to make the meshes intersect.
rajib
Well if you see my above post, you can see they intersect. Here is the actual wireframe view from the Daz Viewport.
Mesh of V4 + Eyebrow
Zay
No, you need to turn the eyebrow so it goes through the head. Then they are intersecting.
rajib
Zay wrote:No, you need to turn the eyebrow so it goes through the head. Then they are intersecting.
Why do you need to turn the eyebrow ? Isn't it supposed to appear over the eyebrow area ?
In any case once any 2 geometries intersect, you will get artifacts. There is no solution for that. That is how Octane behaves as far as I know.
Zay
rajib wrote:Why do you need to turn the eyebrow ? Isn't it supposed to appear over the eyebrow area ?
Because head morphs will usually intersect with the eyebrow on V4.
And to the intersecting problem. That is what I already mentioned earlier. The problem however could be fixed easily if the plugin did NOT load the eyebrow when it is set to be hidden in the Scene Panel. For most other objects the plugin respects that. But in this case the plugin ignores that and load it anyway.
birdovous
Personally, I just set the scale of eyebrow to 1% and move it to -2 along Z axis and problem solved... :)
Birdovous
Master: Core i7 2600K, 32GB RAM, 2x EVGA GTX Titan X (SC)
Slave 1: Core i5 4460, 16GB RAM, 2x EVGA GTX 1080 Ti SC2
Slave 2: Core i7 9700K, 64GB RAM, 2x ASUS RTX 2080 Ti
Return to “DAZ Studio”
