Ahh,, ok.. thank youface_off wrote:You are looking at the Environment dropbox box. Select Daylight Environment there, then the Model property will be available.in Octane Environment->Model I only see daylight - texture and planetary in modo
OctaneRender 2020 for Modo [OBSOLETE]
I have added OSX Enterprise and Studio builds of the plugin to the top of this thread. A reminder that you will need to be running High Sierra to run these versions. Once OctaneX is released, you will be able to use the later OSX version.
- roy_orengo
I have the same problem!
Installed the last plugin for modo mac osx, when MODO 13 and MODO 14 crashes! If i uninstall the plugin all it works fine!
Roy
I link the crash message for MODO 13
Roy
- modo 13 crash.rtf
- (131.86 KiB) Downloaded 307 times
I have upgraded my OSX system to Catalina in preparation for OctaneX, and it now appears the Modo plugin crashes Modo when run on High Sierra. I have removed the OSX installers at the top of this thread. The OSX version will next be available with the OctaneX version of the plugin.I have added OSX Enterprise and Studio builds of the plugin to the top of this thread. A reminder that you will need to be running High Sierra to run these versions. Once OctaneX is released, you will be able to use the later OSX version.
Hi Francois - it would be worth you checking the OctaneX thread at viewtopic.php?f=9&t=71814. There are no Nvidia Cuda drivers for Catalina - so I suggest you ask in that thread if your Nvidia cards can be used.francois wrote:Paul,
there’s something I don’t understand.
There is no nvidia driver after Hight sierra, and an nvidia card is required to launch Octane. so who is this version for ?
Do you have an nvidia card on your mac with Catalina?
