I am working with the correction deformer in Cinema to get selection tags and apply my material keeping everything procedural.
I will explain the scene :
I have a rectangle spline in a Extrude object. I have a Correction deformer that let me select the corner edges so that I can put this edge selection in a Bevel deformer. I know have an Extrude object that is beveled only on the edge corners.
I want to apply different materials on faces and beveled corners. So I put a second Correction deformer to select the beveled faces and the not beveled ones. Problem is that when I apply the octane material to the beveled faces selection tag, the texture doesn't appear.
Any idea how to achieve this ?
