Displacement advanced material
spercic
hi guys..I have a problem and I can't understand ..
I have a mix material with amount dirt:
- wooden base :MAT2
- above a white color mixed with texture :MAT 1
if I want to create a displacement only on white how can I do? (i used bump and it works)
I tried to use displacement on MAT 1: does not work
I don't want displacement on mix material but only on white material and for me it's natural to use the MAT 1 displacement channel :?: :?: :roll: :roll:
thank you and good evening
noldo
It's not possible.
For mix material, the displacement map need to be connected to mix displacement node.
A workaround is a bake displacement of the two material mixed (wood with solid color), connected to mix displacement node.
spercic
hi .. thank you very much ..
I tried without success..I try to make two solids that intersect in the 3d model
noldo
spercic wrote:hi .. thank you very much ..
The manhole cover is displaced, the ground not, only a normal map.
The trick is the mix displacement texture: a displacement of the manhole cover (remember to not tile the texture - clamp value) and a grayscale color for tuning the offset between the two material.
After this, a baking texture (grayscale, HDR) direct connected to the displacement node.
Mix the two material and voilà!
The sample scene used
test.zip
(94 MiB) Downloaded 220 times
spercic
oh wow very kind..study your material and i try to understand.. :shock: :shock: :shock: very complex but wonderful ;) ;) ;)
thank you very much
