OctaneRender™ 2020.1 RC4 [superseded by 2020.1]
Zay wrote:
merid888 wrote:I HAVE PROBLEM, I TRY TO USE THE STANDALONE 2020.1-RC4 VERSION AND BY IMPORTING THE SCENE I SIMPLY SEE NOTHING IN THE RENDER VIEW
SOMEBODY COULD HELP ME ? ATTACHMENT FILE OBJ
THANKS TEAM OCTANERENDER
Try adding a RenderTarget.
Render Target is the best option, but you can also right-click on the geometry node and chose Render Geometry.
Or enable the icon in the Node Graph that allows to render a geometry node, as soon as selected:
ciao Beppe
divasoft
bepeg4d wrote:Hi,
I have four 2020.1 Slave running here, on both Mac Win and Linux, and previously they have RC4, without any issue:
The attachment 537D14E6-B6F7-4924-B31C-94C419A6E34E.jpeg is no longer available
Are you able to render with Standalone 2020.1 on those machines?
Which kind of Nvidia driver is installed?
You need at least a version greater than 435.80. I’m currently using Studio 442.19.
ciao Beppe
I’m not deceiving, my three friends also couldn’t launch Slave node when I asked them to do it.
I don’t think you are deceiving, but I can ensure you that bot 2020.1-RC4 and 2020.1 slaves are running without issues, I couldn’t live without them anymore ;)
Please, check if bitdefender or any other internet software is interferring with the daemon installer.
ciao Beppe
divasoft
bepeg4d wrote:Hi,
ciao Beppe
Beppe, this seems absurd, but here's what I found. If I skip the second question of daemon installer: “how many video cards do you want to use?”, the daemon starts and works. And if I answer it by entering a specific number, then the demon does not work.
divasoft
But still, the masternode now tells me that the version of the slave does not match, although both of them are from the last release. Maybe i do something wrong?
divasoft
bepeg4d wrote:Hi,
ciao Beppe
Standalone works well. Maybe Ahmet incorrectly update the version of latest release for Cinema?
divasoft
bepeg4d wrote:Hi,
ciao Beppe
Beppe, can you try install slave daemon with my scenario when you will input specific number of needed video cards?
UPD: I am a little confused in the versions, now everything is fine. Thanks, help is no longer required, but anyway, please check my daemon installation script
great to hear that you have solved :)
About the daemon script, porobably a typo during GPUs selection, I was able to successfully select 2x GPUs:
Please note that you need to enter the numbers of the desired GPUs separated by a comma, and without spaces in between, like:
1,2,3
Looking forward for your feedback,
ciao Beppe
divasoft
bepeg4d wrote:Hi,
1,2,3
ciao Beppe
Thank you, I don’t know what it was, anyway it works now and it’s good)
KeeWe
Got the same issue. 2020.1 RC4 C4D plugin and the latest daemon from the firt page of this thread... Rc4. C4D plugin tells me it's an incvalid version. meh. -.-
Workaraound with not selecting specific GPUs didn't work.
Edit: latest nvidia studio drivers on both machines.
edit: added screenshots
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
