OctaneRender™ 2020.1 [superseded by 2020.1.1]
- Seekerfinder
@Mojave,
Many thanks for the update. I always look forward to seeing if rounded edges finally works properly, but alas... Am I perhaps doing something wrong here in the settings?
Many thanks,
Seeker
Many thanks,
Seeker
- linograndiotoy
Many thanks,
Seeker
Your radius is way to high:
[/quote]
Last edited by linograndiotoy on Wed Apr 29, 2020 7:59 am, edited 1 time in total.
Sorry, that could not make it to this release but it is currently high in our priority list. I have fixed the list in the initial post accordingly.funk wrote:The thread also states:
"Advanced Display Color Management System | OCIO"
That didnt make it either. Any idea when we'll get OCIO? We need it to load the ACES OCIO configs.
Can you send me the orbx? I'd like to check the rest of the settings.noldo wrote:Bug?
If i create a layered material with universal base material (with transmission in specular mode, high roughness), two specular layer, one sheen layer and one metallic layer, the transmission effect blur only in one direction...
If i disconnect the metallic layer (or one of the specular layer) the render is correct.
The mesh with the material applyed is a simple polygon with no tickness.
Correct render Wrong render
I wasn't able to reproduce the single direction blur with my test scene.
- Elvissuperstar007
- Contact:
I can not activate
- BorisGoreta
- Contact:
In the last year I had two licenses that could run 1 master and 2 nodes. I have extended those licenses but now I can only run 1 node. Has licensing changed in the meantime ?
Very minor bug, not sure what happened, but the Octane logo for this release 2020.1 appears as a white 'document' in the task bar and in the alt-tab menu.
Yet, on desktop it is not a white 'document', it has the correct icon.
I checked the the RC4, 3, etc, but all have the proper grey Octane logo icons in the task bar when opened and in the alt-tab menu.
Just 2020.1 v1 has this glitch.
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Plugs: Enterprise
All the icons look OK for me - I tried the Studio and Enterprise builds of 2020.1 standalone. Can you confirm whether the issue persists after restarting your computer? Nothing has changed regarding the icon so I'm not sure what could be causing it.Notiusweb wrote:Very minor bug, not sure what happened, but the Octane logo for this release 2020.1 appears as a white 'document' in the task bar and in the alt-tab menu.
