C4d S22 / R22 - Empty Octane Menu - FYI
cjadams
Any word with compatibility with Cinema4d S22 (R22) - Just FYI my octane menu is empty now.
I suspect this will need an update.
CJ Adams
nycjunglist
Would also like to know the minimum version of Octane that'll be supported for C4D S22.
Ryzen 9 3950x | 128 GB RAM | 2x 3080Ti
Is it publicly available yet?
SSmolak
For subscribers only at the moment. Downloadable from MaxonID.
natemac00
aoktar wrote:Is it publicly available yet?
Yes.
https://www.maxon.net/en-us/news/press- ... available/
______________
Nate Mac - Chicago, IL
Cinema 4D R26.107 | Octane 2021.1.6
Main: AMD ThreadRipper | Win10 | 32-core | 128GB | RTX A5000 & GTX 2070 SUPER
Slaves: 4x GTX 980 Ti | GTX 1080 | GTX 1070 | GTX 1070Ti
Ok plugin has version control to avoid multi load for different versions. So you can't load R21 version in R22.
cjadams
Sounds like from maxon no recompile needed - so hopefully its easy on your end to change version id
cjadams wrote:Sounds like from maxon no recompile needed - so hopefully its easy on your end to change version id
Maybe my english is not enough, I have a control to avoid the loading of wrong versions. You should wait a proper R22 build.
Btw what's sub version number for R22 you have?
cjadams
Here is the version
Ginz
Me too. Installed Octane on Cinema 4D S22.016 and the Octane menu is empty.
Hope you guys are working on it.
