OctaneRender® for 3ds max® v2020.1-RC2 - 10.06 TEST
paride4331
mbetke wrote:I use this configuration. One denoises. The other ones tones. Both render.
Hi mbetke,
could set your configuration as follow:
1 Titan RTX active (on) prioroty (off) Tone (on) Denoise (on)
2 Titan RTX active (on) priority (on) Tone (on) Denoise (off) > connect monitor/s
Then checking and unchecking denoise?
Let me hear from you.
mbetke
First run it allocated 2.3GB to second card and worked.
I opened the "Octane Device Settings" and found out the cards were not set to each other in the "Peers" column. So I did that. Do I need it peered to each other?
Then 3dsmax crashed for some reason. The scene has around 6GB of textures, another 6GB of geometry and some other stuff. I missed to screenshot it and as soon as the render fails the colored bars grey out.
After reloading the scene I played around and ticked some device settings here and there. It crashes the rendering with RTX in all cases.
In one case the whole scene only needed the memory of one card around 19GB for some reasons.
I also set only one card for rendering which didn't work too.
In Windows Task-Manager the shared memory goes up to 1.4GB sometimes before the render goes down. So it shares something but drops out for some reasons.
Here is the log in all its glory:
OctaneRender Enterprise 2020.1 RC2 (8000004)
CUDA error 2 on device 1: out of memory
  -> failed to allocate device memory
device 1: failed to allocate post-fx buffer
CUDA error 2 on device 0: out of memory
device 0: failed to upload data texture 34 '0:__data31__'
Mismatching barriers, 5 and 2
denoiserThread0 : Not enough free memory to run the denoiser. Required memory 604.92 MB
denoiserThread0 : Initialization failed. Restart required
PURE3D Visualisierungen
samsue
Hey,
Can we wait on the final version of this Build, support for conversation of these materials?
Please! We need Multisubtex!
Seriously... please!
paride4331
mbetke wrote:First run it allocated 2.3GB to second card and worked.
Hi mbetke,
thanks, it seems I can reproduce the issue, I sent my test to developers, I suppose it depends on SDK, we shall see.
coilbook
Hi Paride,
this version splits screen into 4 parts usually visible when default background is behind
rtx enabled creates split lines and different color
And it renders slower when using RTX. That's why when AI Light is on or off with RTX on it also creates different look and brightness
Elvissuperstar007
bug Sun ,HDR, Glossy material, specular material all bug
Elvissuperstar007
not work 2018-2019-2020
paride4331
[quote="mbetke"]First run it allocated 2.3GB to second card and worked.
Hi mbetke,
please try as follow:
set out-of-core to 64mb
set Parallel sample to 2
Max tile to 4
if not crashes, then increase them step by step 4/8 8/16.
coilbook
Hi Paride,
1. were you able to reproduce quad screen splitting during rendering of different brightness ?
2. Octane has strange problem with AO light amount. When these 3 objects are isolated they have nice bright light. When we unhide other objects that also have light light drops to almost to nothing. (the image is attached ) Why does octane do this?
3. old and new volume behavior is still not fixed.
Thank you
paride4331
coilbook wrote:Hi Paride,
Thank you
Hi coilbook,
It could depends on RC2. Waiting for RC3 you could try increasing light sample or checking "keep instance power" option.
Return to “Releases”
