OctaneRender® for 3ds max® v2020.1-RC2 - 10.06 TEST
Elvissuperstar007
direct engine cannot save alpha channel PNG
paride4331
Elvissuperstar007 wrote:direct engine cannot save alpha channel PNG
Hi Elvissuperstar007,
it seems to work.
Rik
First play with rtx and upgrade from v4.
Pleased with the rtx speed up.
However, confused by the AI up-scaling feature.
Is there any instruction from the Octane team on how to use it and what the sliders actually do?
So far I get;
no up-sampling = clear image
2x2 up-sampling = quicker but blurred
4x4 up-sampling = really fast but very, very blurred/unusable
Think I'd get better results upscaling in photoshop or am I missing something?
Certainly not getting anything like the Otoy images of the orange quad bike.
Is there something else I'm supposed to do to find what the AI has been doing?
paride4331
Rik wrote:First play with rtx and upgrade from v4.
So far I get;
Hi Rik,
you should use it together with Denoising. It could help in animation or try to render a larger render, then shrink it.
Rik
Ah. So you need to have AI denoise on as well?
Great, seeing awesome results now thanks.
This just might save my job over the next few weeks for the movies I've been asked to make.
Any top tips on how to tie all this together and make sure there's no flickering noise in the animations?
coilbook
ai light off and on with rtx different brightness
Elvissuperstar007
Started logging on 02.04.20 04:37:13
OctaneRender Enterprise 2020.1 RC2 (8000004)
CUDA error 2 on device 0: out of memory
-> failed to allocate device memory
device 0: failed to allocate post-fx buffer
denoiserThread0 : Not enough free memory to run the denoiser. Required memory 453.47 MB
denoiserThread0: CUDA_ERROR_OUT_OF_MEMORY: out of memory
. Restart required
paride4331
coilbook wrote:ai light off and on with rtx different brightness
Hi coilbook,
are you using any dirt node?
coilbook
Hi coilbook,
Hi Paride,
No. I will try to send the file
Thank you
solomon
Texture environment is not working in this build ~ Edit: it's working
Solomon W. Jagwe
3D Artist/Animator/Modeler | Independent Film Director
http://www.solomonjagwe.com | http://www.nkozaandnankya.com
Return to “Releases”
