OctaneRender™ 2019 for Daz Studio - New Free Tier!
SOULSSAGA
Hi .
Lastest Dazstudio PRIME beta Version Was uploaded in CustomerDownloads directory So Prime users canot Download it .
If possible upload a new Link in PluginDownloads directory.
__
Also Prime Users Canot Post Replies in Beta tread for proper feedback .
viewtopic.php?f=44&t=73445
Hope is Fixed Soon .
__________
Thanks So much
___________
Current TEST build (Octane 2020.1 RC2)
( Not Downloadable by prime users )
https://render.otoy.com/customerdownloads/plugins/e3/43/da/99/OctaneRender_for_DazStudio_2020_1_0_53_PRIME.exe
( Not found )
https://render.otoy.com/plugindownloads/42/6d/ba/53/OctaneRender_for_DazStudio_2020_1_0_53_PRIME.exe
( Not found )
https://render.otoy.com/plugindownloads/e3/43/da/99/OctaneRender_for_DazStudio_2020_1_0_53_PRIME.exe
( Available for prime users download )
https://render.otoy.com/plugindownloads/42/6d/ba/53/OctaneRender_for_DazStudio_2020_1_0_52_PRIME.exe
My apologies, I posted the PRIME build in the wrong area. This is now fixed. viewtopic.php?f=44&t=73445&p=374289#p374289
SparkieShock
I'm having problems getting Octane Prime DAZ (free) to work for my laptop .. my nivdia drivers were recently updated and this seems to have nerfed Octane for me .. can anyone reccomend he best driver to use with Octane Prime?
I already have a proper Octane 4 license (on my other machine) to which drivers 417 work the best .. but this driver will not work for Octane Prime.
Win 10 Pro Edition - Intel i0 10900X - X299 MB - 128GB's KINGSTON FURY 3200 RAM - 2x RTX A6000 GPU's - 1300 Watt Power
DAZ3D - BLENDER - OCTANE STANDALONE and PLUGIN FOR DAZ - OCTANE PRIME for DAZ
you need Nvidia driver 419.67 or greater, for working with Octane v4 or greater.
Then please, download and run OctaneBench 4.00c to check that everything is working correctly:
https://render.otoy.com/downloads/a/787 ... 0c_win.zip
ciao Beppe
hiram67
hello, I have an active license for octane standalone render v. 4.05 and a license for the Poser plugin.
Recently I started using daz3d studio and I saw that the plugin is available for free. I downloaded and installed the plugin, but it tells me it can't be activated. Could you help me, thanks?
hiram67 wrote:hello, I have an active license for octane standalone render v. 4.05 and a license for the Poser plugin.
I suggest opening a ticket with OTOY to resolve this via the Support button at the top of this page.
Dartanbeck_1
From someone who has never tried Octane,
Thanks Otoy!!!
Looking forward to this! :)
alexej32
I finally decided to try Octane plugin with Daz Studio but i get errors when when i start DS :(
"Pin/NodeType enumeration missmatch!" followed by "Could not initialise projectDB!".
After clicking "Accept" on the error popups DS sill launches but when i close DS, it keeps
running in the background and the only way to stop it it's by "killing it" in the taskmanager.
This is what the debug log contain:
2020-12-19 10:33:01.140 2396 b2020.1.0.55 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2020-12-19 10:33:01.140 2396 b2020.1.0.55 +++++ Plugin started.
2020-12-19 10:33:01.320 2396 b2020.1.0.55 +++++ SQL = ERROR +++++ 1
2020-12-19 10:33:01.320 2396 b2020.1.0.55 + conn. name : mem_db
2020-12-19 10:33:01.320 2396 b2020.1.0.55 + dtbase text : near "S": syntax error
2020-12-19 10:33:01.321 2396 b2020.1.0.55 + driver text : Unable to execute statement
2020-12-19 10:33:01.321 2396 b2020.1.0.55 + --> last query : ATTACH DATABASE 'C:/Users/MOBY'S~1/AppData/Local/Temp/qt_temp.q20228' AS [temp_db]
2020-12-19 10:33:01.322 2396 b2020.1.0.55 +++++++++++++++++++++++
2020-12-19 10:33:01.323 2396 b2020.1.0.55 +++++ SQL = ERROR +++++ 1
2020-12-19 10:33:01.323 2396 b2020.1.0.55 + conn. name : mem_db
2020-12-19 10:33:01.323 2396 b2020.1.0.55 + dtbase text : no such table: PinTypes
2020-12-19 10:33:01.324 2396 b2020.1.0.55 + driver text : Unable to execute statement
2020-12-19 10:33:01.324 2396 b2020.1.0.55 + --> last query : SELECT * FROM [PinTypes]
2020-12-19 10:33:01.325 2396 b2020.1.0.55 +++++++++++++++++++++++
2020-12-19 10:34:23.452 18396 b2020.1.0.55 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2020-12-19 10:34:23.453 18396 b2020.1.0.55 +++++ Plugin started.
2020-12-19 10:34:23.562 18396 b2020.1.0.55 +++++ SQL = ERROR +++++ 1
2020-12-19 10:34:23.562 18396 b2020.1.0.55 + conn. name : mem_db
2020-12-19 10:34:23.562 18396 b2020.1.0.55 + dtbase text : near "S": syntax error
2020-12-19 10:34:23.563 18396 b2020.1.0.55 + driver text : Unable to execute statement
2020-12-19 10:34:23.563 18396 b2020.1.0.55 + --> last query : ATTACH DATABASE 'C:/Users/MOBY'S~1/AppData/Local/Temp/qt_temp.U24448' AS [temp_db]
2020-12-19 10:34:23.564 18396 b2020.1.0.55 +++++++++++++++++++++++
2020-12-19 10:34:23.565 18396 b2020.1.0.55 +++++ SQL = ERROR +++++ 1
2020-12-19 10:34:23.565 18396 b2020.1.0.55 + conn. name : mem_db
2020-12-19 10:34:23.565 18396 b2020.1.0.55 + dtbase text : no such table: PinTypes
2020-12-19 10:34:23.566 18396 b2020.1.0.55 + driver text : Unable to execute statement
2020-12-19 10:34:23.566 18396 b2020.1.0.55 + --> last query : SELECT * FROM [PinTypes]
2020-12-19 10:34:23.566 18396 b2020.1.0.55 +++++++++++++++++++++++
2020-12-19 10:37:04.253 32868 b2020.1.0.55 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2020-12-19 10:37:04.254 32868 b2020.1.0.55 +++++ Plugin started.
2020-12-19 10:37:04.363 32868 b2020.1.0.55 +++++ SQL = ERROR +++++ 1
2020-12-19 10:37:04.363 32868 b2020.1.0.55 + conn. name : mem_db
2020-12-19 10:37:04.363 32868 b2020.1.0.55 + dtbase text : near "S": syntax error
2020-12-19 10:37:04.364 32868 b2020.1.0.55 + driver text : Unable to execute statement
2020-12-19 10:37:04.364 32868 b2020.1.0.55 + --> last query : ATTACH DATABASE 'C:/Users/MOBY'S~1/AppData/Local/Temp/qt_temp.Q10828' AS [temp_db]
2020-12-19 10:37:04.364 32868 b2020.1.0.55 +++++++++++++++++++++++
2020-12-19 10:37:04.365 32868 b2020.1.0.55 +++++ SQL = ERROR +++++ 1
2020-12-19 10:37:04.366 32868 b2020.1.0.55 + conn. name : mem_db
2020-12-19 10:37:04.366 32868 b2020.1.0.55 + dtbase text : no such table: PinTypes
2020-12-19 10:37:04.366 32868 b2020.1.0.55 + driver text : Unable to execute statement
2020-12-19 10:37:04.367 32868 b2020.1.0.55 + --> last query : SELECT * FROM [PinTypes]
2020-12-19 10:37:04.367 32868 b2020.1.0.55 +++++++++++++++++++++++
2020-12-19 10:37:44.051 26700 b2020.1.0.55 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2020-12-19 10:37:44.051 26700 b2020.1.0.55 +++++ Plugin started.
2020-12-19 10:37:44.163 26700 b2020.1.0.55 +++++ SQL = ERROR +++++ 1
2020-12-19 10:37:44.164 26700 b2020.1.0.55 + conn. name : mem_db
2020-12-19 10:37:44.164 26700 b2020.1.0.55 + dtbase text : near "S": syntax error
2020-12-19 10:37:44.164 26700 b2020.1.0.55 + driver text : Unable to execute statement
2020-12-19 10:37:44.165 26700 b2020.1.0.55 + --> last query : ATTACH DATABASE 'C:/Users/MOBY'S~1/AppData/Local/Temp/qt_temp.r25324' AS [temp_db]
2020-12-19 10:37:44.165 26700 b2020.1.0.55 +++++++++++++++++++++++
2020-12-19 10:37:44.166 26700 b2020.1.0.55 +++++ SQL = ERROR +++++ 1
2020-12-19 10:37:44.166 26700 b2020.1.0.55 + conn. name : mem_db
2020-12-19 10:37:44.166 26700 b2020.1.0.55 + dtbase text : no such table: PinTypes
2020-12-19 10:37:44.167 26700 b2020.1.0.55 + driver text : Unable to execute statement
2020-12-19 10:37:44.167 26700 b2020.1.0.55 + --> last query : SELECT * FROM [PinTypes]
2020-12-19 10:37:44.167 26700 b2020.1.0.55 +++++++++++++++++++++++
2020-12-19 10:49:40.133 7856 b2020.1.0.55 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2020-12-19 10:49:40.134 7856 b2020.1.0.55 +++++ Plugin started.
2020-12-19 10:49:40.303 7856 b2020.1.0.55 +++++ SQL = ERROR +++++ 1
2020-12-19 10:49:40.304 7856 b2020.1.0.55 + conn. name : mem_db
2020-12-19 10:49:40.304 7856 b2020.1.0.55 + dtbase text : near "S": syntax error
2020-12-19 10:49:40.304 7856 b2020.1.0.55 + driver text : Unable to execute statement
2020-12-19 10:49:40.305 7856 b2020.1.0.55 +
2020-12-19 10:49:40.305 7856 b2020.1.0.55 + --> last query : ATTACH DATABASE 'C:/Users/MOBY'S~1/AppData/Local/Temp/qt_temp.g17472' AS [temp_db]
2020-12-19 10:49:40.305 7856 b2020.1.0.55 +++++++++++++++++++++++
2020-12-19 10:49:40.306 7856 b2020.1.0.55 +++++ SQL = ERROR +++++ 1
2020-12-19 10:49:40.307 7856 b2020.1.0.55 + conn. name : mem_db
2020-12-19 10:49:40.307 7856 b2020.1.0.55 + dtbase text : no such table: PinTypes
2020-12-19 10:49:40.307 7856 b2020.1.0.55 + driver text : Unable to execute statement
2020-12-19 10:49:40.308 7856 b2020.1.0.55 + --> last query : SELECT * FROM [PinTypes]
2020-12-19 10:49:40.308 7856 b2020.1.0.55 +++++++++++++++++++++++
2020-12-19 10:52:48.670 7856 b2020.1.0.55 +++++ Plugin ended.
2020-12-19 10:52:48.671 7856 b2020.1.0.55 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2020-12-19 10:58:20.205 18164 b2020.1.5.55 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2020-12-19 10:58:20.205 18164 b2020.1.5.55 +++++ Plugin started.
2020-12-19 10:58:20.382 18164 b2020.1.5.55 +++++ SQL = ERROR +++++ 1
2020-12-19 10:58:20.382 18164 b2020.1.5.55 + conn. name : mem_db
2020-12-19 10:58:20.382 18164 b2020.1.5.55 + dtbase text : near "S": syntax error
2020-12-19 10:58:20.383 18164 b2020.1.5.55 + driver text : Unable to execute statement
2020-12-19 10:58:20.383 18164 b2020.1.5.55 + --> last query : ATTACH DATABASE 'C:/Users/MOBY'S~1/AppData/Local/Temp/qt_temp.aS3440' AS [temp_db]
2020-12-19 10:58:20.384 18164 b2020.1.5.55 +++++++++++++++++++++++
2020-12-19 10:58:20.385 18164 b2020.1.5.55 +++++ SQL = ERROR +++++ 1
2020-12-19 10:58:20.385 18164 b2020.1.5.55 + conn. name : mem_db
2020-12-19 10:58:20.385 18164 b2020.1.5.55 + dtbase text : no such table: PinTypes
2020-12-19 10:58:20.385 18164 b2020.1.5.55 + driver text : Unable to execute statement
2020-12-19 10:58:20.386 18164 b2020.1.5.55 +
2020-12-19 10:58:20.386 18164 b2020.1.5.55 + --> last query : SELECT * FROM [PinTypes]
2020-12-19 10:58:20.386 18164 b2020.1.5.55 +++++++++++++++++++++++
2020-12-19 11:01:28.526 18164 b2020.1.5.55 +++++ Plugin ended.
2020-12-19 11:01:28.527 18164 b2020.1.5.55 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2020-12-19 11:03:49.931 19180 b2020.1.4.55 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2020-12-19 11:03:49.932 19180 b2020.1.4.55 +++++ Plugin started.
2020-12-19 11:03:50.042 19180 b2020.1.4.55 +++++ SQL = ERROR +++++ 1
2020-12-19 11:03:50.042 19180 b2020.1.4.55 + conn. name : mem_db
2020-12-19 11:03:50.043 19180 b2020.1.4.55 + dtbase text : near "S": syntax error
2020-12-19 11:03:50.043 19180 b2020.1.4.55 + driver text : Unable to execute statement
2020-12-19 11:03:50.044 19180 b2020.1.4.55 + --> last query : ATTACH DATABASE 'C:/Users/MOBY'S~1/AppData/Local/Temp/qt_temp.F18556' AS [temp_db]
2020-12-19 11:03:50.044 19180 b2020.1.4.55 +++++++++++++++++++++++
2020-12-19 11:03:50.045 19180 b2020.1.4.55 +++++ SQL = ERROR +++++ 1
2020-12-19 11:03:50.045 19180 b2020.1.4.55 + conn. name : mem_db
2020-12-19 11:03:50.046 19180 b2020.1.4.55 + dtbase text : no such table: PinTypes
2020-12-19 11:03:50.046 19180 b2020.1.4.55 + driver text : Unable to execute statement
2020-12-19 11:03:50.047 19180 b2020.1.4.55 + --> last query : SELECT * FROM [PinTypes]
2020-12-19 11:03:50.047 19180 b2020.1.4.55 +++++++++++++++++++++++
2020-12-19 11:07:02.054 19180 b2020.1.4.55 +++++ Plugin ended.
2020-12-19 11:07:02.054 19180 b2020.1.4.55 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2020-12-19 11:44:12.679 27772 b2020.1.4.55 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2020-12-19 11:44:12.680 27772 b2020.1.4.55 +++++ Plugin started.
2020-12-19 11:44:12.791 27772 b2020.1.4.55 +++++ SQL = ERROR +++++ 1
2020-12-19 11:44:12.791 27772 b2020.1.4.55 + conn. name : mem_db
2020-12-19 11:44:12.791 27772 b2020.1.4.55 + dtbase text : near "S": syntax error
2020-12-19 11:44:12.792 27772 b2020.1.4.55 + driver text : Unable to execute statement
2020-12-19 11:44:12.792 27772 b2020.1.4.55 + --> last query : ATTACH DATABASE 'C:/Users/MOBY'S~1/AppData/Local/Temp/qt_temp.gi9524' AS [temp_db]
2020-12-19 11:44:12.793 27772 b2020.1.4.55 +++++++++++++++++++++++
2020-12-19 11:44:12.793 27772 b2020.1.4.55 +++++ SQL = ERROR +++++ 1
2020-12-19 11:44:12.794 27772 b2020.1.4.55 + conn. name : mem_db
2020-12-19 11:44:12.794 27772 b2020.1.4.55 + dtbase text : no such table: PinTypes
2020-12-19 11:44:12.794 27772 b2020.1.4.55 + driver text : Unable to execute statement
2020-12-19 11:44:12.795 27772 b2020.1.4.55 +
2020-12-19 11:44:12.795 27772 b2020.1.4.55 + --> last query : SELECT * FROM [PinTypes]
2020-12-19 11:44:12.795 27772 b2020.1.4.55 +++++++++++++++++++++++
Found an old thread on the forums about this issue and followed the suggestion deleting the Data folder in C:\Users\*username*\OctaneRender
and reinstalling the plugin but the errors sill acccure :(
I'm running Daz Studio 4.14.0.8 Pro (x64) with the Octane Render Kit installed on a Win 10 Pro(x64)/32Gb RAM /Asus Geforce RTX 2070 Super.
Woud really appriciate help on this matter
segoe
I'm not able to download the PRIME/FREE version of the new 2020 test version here: viewtopic.php?f=44&t=77593
"Your customer/forum accounts do not have permission to download this file, please login to a licensed account to download this file."
JoannaCurry
I have questions:
I'm confused, Octane Prime License shows up under my subscriptions but it says it's paid till the end of the year.
Is this the free-tier subscription license and if so what happens to it on January 1st 2020? Is this just a trial?
Is the only way to download free tier through this forum thread or should it be seen under accounts, eventually?
Why does my old v4 subscription say it's active but doesn't have all access under its license info (perpetual)?
What is all access and what not having all access means?
